Thread: Kreepy Krauly Classic is leaning to one side
    Jun 2011
    San Diego California
    88
    After 3 years, my Kreepy Krauly Classic is acting strange and I cannot seem to figure out why. With the pump off, the cleaner sits flat on the bottom, and the body and hose are generally at 45 degrees as per the manufacturers suggested weighting of the hose. However, as soon as the pump starts, the whole body of the cleaner leans to one side. It is not in the axis of the hose being too high or to low, but perpendicular to the hose/body of the cleaner.
    It will gradually skid along the bottom, but as its leaning over to one side, it never gets suction. If I force it level it will regain suction and clean as normal until it falls from a side, or hits the stairs, or something causes it to lose suction (as is normal). After that, it never regains suction again as it just leans over and skids around.
    - I have checked all the moving parts and everything seems to move with ease.
    - I cannot see anything blocked in the flapper
    - I removed an in-line hose basket
    - I've shifted the hose weights a little to see if it had any effect, but nothing
    - It uses a sectional hose, so I switched up the order of pieces, but there does not seem to be any memory in the overall hose
    - I have tried a wide variety of pump RPM's, but no difference, just changes the speed it skids around on its side.
    - I thought maybe the dive floats were rotten on one side (causing buoyancy on the other), so I replaced the entire dive float, but no change.
    Any ideas on problem parts to replace, or other ides why it would suddenly lean to one side as soon as the pump turns on? It almost seems like the suction torques the whole body to one side.
    IG, 13,000 gal, concrete, DE, VS Intelliflo Pump, Intellichlor SWG
    San Diego, Ca.
    Jun 2011
    88
    Re: Kreepy Krauly Classic is leaning to one side
    Any suggestions?
    San Diego, Ca.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    There are a couple of things you could check. Look for air leaks in the hoses and the above ground plumbing from the pool to the pump. Make sure the pool is filled to at least 1/2 way up the skimmer. Check the hose sections for cracks and chips where the hoses connect, also make sure you are not missing any hose weights. Check all the joints in the above ground plumbing to the pump for air leaks by drizzling water slowly over the joints and watching for the water to get sucked into the pipe. Also check that the drain on them pump strainer pot is snug and the o-ring in the pump strainer lid is well lubed with silicone pool lube.
    Love TFP? Become a
    TFP Supporter!
    Jun 2011
    88
    I have a few poor hose connections but I swapped those and didn't see any change. However I totally dismantled the cleaner and looked everywhere for issues. After I didn't see any I re assembled it. Something changed as it now is working again.
    San Diego, Ca.
