Thread: CSI ?
    cnatra's Avatar
    Feb 2014
    Houston TX
    187
    CSI ?
    So what do I need to know about CSI & how to adjust it ??
    FC 8.8
    CC 0.0
    PH 7.4
    TA 150
    CH 100
    CYA 30
    CSI is -.28
    according to the pool math calculator
    Thx
    23k gunite, Stonescapes Mini Aqua Blue w/seashell, Pentair CCP520 cartridge filter, 2 Pentair Intelli-Flo VS pumps, Pentair Mastertemp 400, Pentair EasyTouch 8+wireless controller, Silencer spa blower, 3 Intellibrite LEDs, Pentair Racer cleaner, Pentair 320 chlorinator
    my build http://www.troublefreepool.com/threa...-north-Houston
    30,408
    Re: CSI ?
    I have never used CSI. If you keep the parameters we test for in their respective ranges, CSI is not a factor and there is no need for it.
    Re: CSI ?
    CSI is mostly only used by people with high fill water calcium levels. Normally you can just ignore it.
    cnatra's Avatar
    Feb 2014
    Houston TX
    187
    Re: CSI ?
    OK , Thanks
    38,260
    Re: CSI ?
    Yours is still in the range listed in PoolMath. The reason it is a little low is because your CH is out of spec low. The higher TA is offsetting the low CH some.
    Mar 2011
    Houston, Texas
    413
    Re: CSI ?
    Quote Originally Posted by JasonLion View Post
    This is my situation. My fill water is around 150 CH and my pool usually tests between 475 and 525 CH. I watch my CSI like a hawk and I keep it slightly negative. I've had no issues with scaling.
    9,200 gal. Gunite Luna Quartz French Grey pool with spill over spa, two fountains on tanning ledge (rarely used)
    Pentair Whisperflo 2HP, Pentair CCP Cartridge 420 Sq. Ft., Polaris 280 with booster pump
    Pentair EasyTouch 4, RayPak LoNox 266k Natural Gas heater, Aqua Rite SWCG T Cell 9, Borates, TF-100 test kit
