Results 1 to 10 of 10
Thread: help me get my water chem right
    Apr 2014
    Louisiana
    51
    PH 7.6
    Total ALk 110
    Calcium hardness 50
    Cyanuric acid 30
    FC 3
    TC 3.3
    Copper, iron, mang - 0
    salt 1900
    The pool is starting to get a little green on the sides. I basically need it ready by next weekend for a Crawfish Boil
    30,000
    IG (in ground)
    vinyl
    sand filter
    SWG
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: help me get my water chem right
    If you have the right test kit, it should be no problem getting the pool shaped up in time. But those look like pool store results.
    In brief, add acid to get pH to 7.2 and then ignore it until the SLAM process is complete. SLAM it. Brush until your arms feel like they're going to fall off. Pay close attention to the prerequisites listed in the SLAM article. And post pictures before, during, and after!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,600
    I doubt that's a high enough salt level for your SWG to be producing anything and your cya is too low for it. SLAM it then check those. See the recommended test kits in pool school.
    Apr 2014
    Louisiana
    51
    i have the 100. I am out of which ever reagent tests the chlorine though, so i took it to the store for testing
    is one of those measurements 'CYA' ?
    30,000
    IG (in ground)
    vinyl
    sand filter
    SWG
    Apr 2014
    Louisiana
    51
    nvm
    cyanuric acid
    30,000
    IG (in ground)
    vinyl
    sand filter
    SWG
    Apr 2014
    Louisiana
    51
    Is Calcium hardness something i should deal with now as well? it seems way off
    30,000
    IG (in ground)
    vinyl
    sand filter
    SWG
    Richard320's Avatar
    Jan 2010
    18,995
    Quote Originally Posted by whodat?2 View Post
    No. You have a vinyl pool. It won't be damaged the waya plaster pool will. Adjust pH, then SLAM. The rest of the stuff is really easy to fix later.
    Apr 2014
    Louisiana
    51
    great, off to dollar general and home depot after work! thanks
    30,000
    IG (in ground)
    vinyl
    sand filter
    SWG
    Apr 2014
    Louisiana
    51
    i should raise the CYA to at least 60 right? or is it better to have it low to SLAM ?
    30,000
    IG (in ground)
    vinyl
    sand filter
    SWG
    Apr 2010
    East Texas
    9,600
    Don't raise cya till you're done.
