Thread: New member, new owner
    May 2014
    Inverness Fl
    53
    Already been reading and searching your forum as a new owner of in-ground pool, very nice forum very informative. Have already read a lot of useful info. and comments. Thanks.
    My pool just got finished. Reading here has gotten me to email the installers to see if the pool is being kept in it's state now on purpose because of the fresh state of the interior surface, so a very low ph and no chlorine by my test. The in pool cleaning system and shimmer are not being run or used, even though the pump is being run to circulate the water. What do you think, seems to me the water should be brought into norm right now? Hey, what do I know, I'm a rookie.
    Re: New member, new owner
    Welcome!
    What surface ? Plaster / fibreglass / vinyl liner?
    Because of warranty I would follow what the pool builder advises , but it's good that you're querying them , some could be a bit lax
    Sydney, AU | IG concrete / glass bead | ~8,000 Gal Kidney Shape | speck 90/230 w/Auto Clear SWG & Davies Sand filter|speck supersport swim jet | Attached Raised Spa | Pool just resurfaced |the pool cleaner | solar heated
    May 2014
    Inverness Fl
    53
    Thanks
    Surface is your typical concrete/gunite with a florida gem surface. Just finished 2 days ago/filled with water.
    Ahh nice one , I take it was an acid wash startup ?
    See here - http://www.troublefreepool.com/conte...w-pool-plaster
    For the most common way to start up a fresh plaster pool , but your pool builder should really do this - check that they have done the initial acid wash and the water is ready to be balanced.
    Then my recommendation is (if its an acid startup)-
    Test water first if all to see what it needs with a good quality test kit ( tf100 / taylor k2006)
    Add cal-stop / scale inhibitor
    Wait for 48hrs before adding chlorine after fill , and either liquid chlorine or trichlor pucks (which also add cya- stabiliser ) , I would add 3-5ppm with no cya in there yet
    Get the ph in the 7.2-7.6 mark ( first weeks it will tend to rise) check daily!
    Get the total alkalinity to 80-120
    Get Calcium harness to at least 150 if not 200 to begin with as this tends to rise over the first few weeks although not always, eventually after 4 week you should be at 250-300
    And brush brush brush ! With a nylon brush twice a day for the first 2 weeks
    Optional is a sequestering agent to avoid metal stains , preferably a hedp based one instead of edta based. ( I personally didn't add any because I wasn't using well water)
    After 3 days I gradually added cya to initially get it to 30ppm, if its a salt water pool I would gradually increase it to 60-80 but go slow at first
    And NO Salt for the first 28 days if its a salt chlorine generator
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to the forum ryker
    It sounds like they are doing acid startup. They should be in control of it and keep you posted. If you want to do the pool care, you need two things. Knowledge and a good test kit. Start with the ABCs in Pool School, and work on the rest as much as you can. The only kit I suggest for your pool type and size is the TF100.
    Ask questions as you need too, and we'll be glad to help.
    Essential Links:
