Results 1 to 11 of 11
Thread: intex adjustable pool inlet nozzle
    itodd's Avatar
    Jul 2013
    Gastonia, NC
    50
    I have the 14 foot round (4 feet deep) Intex Ultra Frame pool. This is my second year with it. As many have done, I upgraded to the 2500 g/hour pump. Of course this meant I had to cut bigger holes for the intake and outlet nozzles.
    My question deals with the adjustable pool inlet nozzle. This is the one that has the moveable "eye." I hooked it up and turned on the pump and the water coming out was just crazy. It was spraying out the sides where it tightens around the threads. I tighten it up, I loosen it. Finally I removed the intex adjustable pool inlet nozzle and was examining it and the inside has this clear plastic ring that basically covers all of the holes on the nozzle except for the eye.
    What is the purpose of this plastic ring? It is blocking the water flow and forcing the water to only come out of the eye and due to the pressure the water is also coming out around the threads.
    4600 gallons, Intex Ultra Metal Frame 14' round 4' depth, SWG, cartridge filter pump, 2500 gph, Pool finish date: 7/16/13.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Re: intex adjustable pool inlet nozzle
    I know exactly what you mean, you can pull that part out, it just directs the water out the adjustable part of it... I have removed mine, but the water will be dispersed differently.... The water just wont be as direct, but if you have a powerful pump it shouldn't make a difference...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Jun 2013
    Newcastle, Oklahoma
    508
    the intex eye return is horrible. If you get the Hayward Dyna Skimmer (which will make a night and day difference on getting surface trash out of your pool) it comes with a Hayward eye return that is MUCH better than the crappy intex one. It directs a very tight stream of water and has my pool swirling like a whirlpool.
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    itodd's Avatar
    Jul 2013
    Gastonia, NC
    50
    Quote Originally Posted by gtnos View Post
    Would the Dyna Skimmer fit the 1 1/2" hole that the current intex occupies?
    Quote Originally Posted by laceygirl View Post
    I pulled the plastic out too and realized I would never get it back in. Just doesn't make sense to have the holes there if they will be covered up with the plastic.
    Apr 2013
    Battle Creek, MI
    298
    I removed every other one of those clear plastic "flaps" on the Intex fisheye when I went with the Hayward pump. I may try and adapt the inlet that came with my skimmer this season.
    18'x4' AG Intex Ultra Frame, 6,700 gal., assembled new 2013; Mods: Hayward EC50C90 Perflex filter & 1 h.p. PowerFlo Matrix pump, Fiber Clear cellulose D.E. substitute, Hayward H100ID1 100,000 BTU NG heater, a pair of 2'x20' Sungrabber solar heaters via the original Intex 635T pump, grey Hydro Tools through-the-wall skimmer, Confer steps/ladder system & Cover Free chemical pool cover. The Summer of Mods!
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    I'm not sure, but i think the plastic flap is a bit of "idiot proofing" for those people who put that return on the intake side so the pump doesn't get starved. Think check valve or one-way valve. That's the only reasonable explanation I can think of.
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    I never had any intex eyeball returns, but when I switched to hayward fittings a few weeks ago I tried the hayward eyeball...then through a series of events I tried a threaded pvc elbow I happened to have and I love it! No eyeballs for me! My elbow has a crazy whirlpool going without having to create the restriction that the "real" eyeball created. LOL
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    Jun 2013
    Newcastle, Oklahoma
    508
    Quote Originally Posted by Beens View Post
    yeah, I have thought about going with a pvc elbow too, much as I like the hayward eye. However, the pvc elbow would probably do a better job of directing debris into my skimmer...
    Quote Originally Posted by itodd View Post
    the skimmer itself? no. You have to cut a square hole 6~8 inches or so and mount it through the liner. Its not near as hard as it sounds and in the intex sticky there are good instructions for doing so. its a very easy and worthwhile mod.
    as far as the hayward eye ball return that comes with it, it went right in where the intex one was, no modification needed.
    itodd's Avatar
    Jul 2013
    Gastonia, NC
    50
    Thank you everyone. This site is always such a help with any questions I have.
    Apr 2014
    United States
    4
    Its the smallish (3/4"?) hole in the hayward eyeball enough for 2500 GPH? Seems restrictive. I was thinking about trimming or cutting out some flaps on the Intex one too.
    Feb 2013
    Yukon, Oklahoma
    220
    That 3/4 should do just fine and the 1 inch one also interchanges in the same threaded hole. So if you don't like the flow with the 3/4, then have the 1 inch standing by. You should be able to find all this stuff at your local Leslies store, pool store, or if you can wait, Amazon.
    Now, may I suggest that you do a google search for a venturi pool return. It fits in the "standard" Hayward return and will allow you to have a good 60 to 45 degree flow that will stir water in the pool. I did it for mine to move the water around for better "mixing" of my heated water. No more cooler areas in the pool now. I did dremel out the inner part of the venturi just a bit.....probably didn't need to but oh my does the water move with this thing.
    I did leave the original Intex skimmer in and cut the liner and put the Hayward skimmer in.....it's worth the effort to install if your doing the hard plumb.
    Bob E.
