I just had an intellichlor 40 installed in my pool. Last year I was running the pool with the BBB method (thanks TFP!!!). Anyhow - does this thing turn off? Do all the lights go off or does it just stay with the no-flow red light when the pump is off.
Also, is there a way to force it to do a salt check. It says it does one when it is first turned on and every 12 hours of usage. Do I need to unplug it or switch off the breaker to trick it into starting up again and doing a salt check?
Thanks
Rich
Thanks
Rich
