Thread: Adding Chlorine, Muriatic Acid and Baking Soda
    First Pool Judith's Avatar
    Feb 2014
    Georgetown, Texas
    57
    Using the pool calculator, I'm getting the measurements for what I need. Is there a technique to adding liquid Chlorine, Muriatic Acid and Baking Soda? Can you add them one after the other OR should I wait a certain period of time before I add other chemicals?
    FC is at 3 want to get it to 5
    PH is at 8 trying to get it to 7.4
    TA is at 70 trying to get it to 80
    Thank you!
    Judith and Brian D
    16,000 gal; IG Quartscape; Cartridge Jandy CV460 (150 gpm Max); Jandy Pro 2.0 Variable
    Polaris PB460 3/4 booster; Polaris 280 Cleaner; In Line Chlorinator Tri-Chlor (don't use it) Ozonator
    Fill Date 11/11/2013
    Casey's Avatar
    SW PA
    10,438
    Re: Adding Chlorine, Muriatic Acid and Baking Soda
    Bring your pH down with the MA. Retest it in a half hour. If it's still high, dose again and retest and then if it's where you want it, go ahead and add the chlorine. If your pH is creeping, I'd leave your TA alone.
    Smykowski's Avatar
    Sep 2011
    3,065
    Acid first, wait 20 min.
    Bleach next, wait 20 min.
    Baking soda can be done last, no rush on TA.
    Pour liquids slowly in frontt of a return jet with the pump running. Predissolve solids in a bucket before pouring in the pool.
    38,279
    I too would leave the TA alone for now.
    Vegas Kid's Avatar
    Dec 2013
    Cypress TX
    187
    Once you put the MA in, you may want to brush right away to prevent any type of staining on the plaster.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,600
    I personally just broadcast baking soda out in the front of the upturned return.
