Thread: When to clean cartridge filter ?
    cnatra's Avatar
    Feb 2014
    Houston TX
    187
    So the pool is almost 8 weeks old
    If I understand correctly I shouldn't need to clean the filter more than a couple times a year but should I go ahead & do any early clean of the filter cartridges
    just to get all the gunk out of there after the new construction ?
    23k gunite, Stonescapes Mini Aqua Blue w/seashell, Pentair CCP520 cartridge filter, 2 Pentair Intelli-Flo VS pumps, Pentair Mastertemp 400, Pentair EasyTouch 8+wireless controller, Silencer spa blower, 3 Intellibrite LEDs, Pentair Racer cleaner, Pentair 320 chlorinator
    my build http://www.troublefreepool.com/threa...-north-Houston
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: When to clean cartridge filter ?
    That would be a good idea. Construction dust and all that will affect your water, but not that much. It could drive your TA and pH up a bit.
    38,268
    You should clean the filter whenever the pressure rises 20-25% over the clean pressure. Would not hurt to start fresh and get the construction remains out of it though.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Long term, you probably won't need to clean more than once a year. I have a smaller filter than yours and I only clean mine once per year and I never make it to the 20% mark. I get only about a 1 PSI rise over the year.
    Mark
    cnatra's Avatar
    Feb 2014
    Houston TX
    187
    well I think in the next week or two I may tackle rinsing those filter cartridges off
    we had tons of pollen in late March, add that to the last bits of construction (grinding the spa spillover after pool was filled)
    I think it may be worth it to go ahead & learn how now
    Vegas Kid's Avatar
    Dec 2013
    Cypress TX
    187
    I cleaned mine after the first month of use. I was very surprised at the amount of plaster dust on the cartridge. Now it's nice and shiny.....
