Results 1 to 11 of 11
Thread: safety cover grommets
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    492
    I remember seeing something about this, but can't find it now! I am going to redo the surface of my concrete pool deck with the Rustoleum Restore product. I know I've see somewhere that the anchors for the safety cover should be lubed for the summer so they will easily come up in the fall. My question is..with Vaseline or pool lube or WD-40? I want to do this before I use the Restore because I KNOW I will accidentally get some of that in one of those, no matter how hard I try!
    Thank you!!
    10,700 gal IG vinyl
    Pentair Triton II TR50 sand filter
    Hayward SharkVac XL cleaner; Emerson 1HP pump
    Bioguard Mineral Springs SWG
    2 skimmers
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    492
    Re: safety cover grommets
    Okay...am I not wording it right so that you know what I'm talking about??? Here's a pic...
    Do these need pool lube or the like in/on them to keep them pliable for the fall closing?
    Thanks!!
    10,700 gal IG vinyl
    2 skimmers
    Sep 2012
    Noblesville, IN
    83
    I take mine out and spray the threads with silicone when I open and close to make sure they turn easily. I haven't had a problem yet but it's cheap insurance. I don't know how Rustoleum will affect them.
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    492
    Quote Originally Posted by mmcgovern View Post
    I take mine out and spray the threads with silicone when I open and close to make sure they turn easily. I haven't had a problem yet but it's cheap insurance. I don't know how Rustoleum!
    Thank you! That's what I was talking about really... If the Rustoleum gets in it, it good bye...this stuff is like painting with Cream of Wheat! And then it dries to solid concrete. I've done well so far in keeping it out of the grommet. But, I'm wondering if I put some petroleum jelly on them if that would help if I do get some in there...kinda like when your painting doors, you use that on the door handles and get paint on the handle..the paint will come right off! The silicone sounds good though. Think I'll run with that.. Thanks for the quick response!
    10,700 gal IG vinyl
    2 skimmers
    Apr 2014
    Hackettstown, NJ
    35
    I use a product from the auto parts store called "Copper Kote" and I can turn most of mine by fingertips.
    25.5K gal vinyl IGP 3.5' - 8' depth. 1.5HP single speed A.O. Smith C48L2N134B1 motor on a Hayward SP2610X15 Pump. 40 ft2 D.E. Filter Hayward model EC75A. Hayward Chlorinator model CL200. single skimmer, 2 Returns. TF100 Test Kit/Speed Stir.
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    492
    Quote Originally Posted by DHoover85 View Post
    Hmm...interesting..okay...maybe I'll give that a shot. I know with silicone it does need to be reapplied every so often....at least it does on my sliding glass door and windows. Do you also need to reapply the "Copper Kote"? Is it similar to silicone or is it "thicker" for a lack of a better word...?
    10,700 gal IG vinyl
    2 skimmers
    38,508
    Look for some anti-seize, that is likely what the copper coat is. Just prevents metals from seizing together ... always good to use on dissimilar metals, but should work for this too.
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    492
    Is that something that is available at the auto supply or would I get that somewhere else?
    10,700 gal IG vinyl
    2 skimmers
    Apr 2014
    Hackettstown, NJ
    35
    I buy it at NAPA auto parts, and I re-apply it in the spring when the cover comes off. just back the anchors out and "paint" the threads. just a bit is plenty. if it starts to build up in the holes and impede the anchors going down flush, use an old toothbrush and clean it out a bit. and yes it is an anti-seize product with copper added to resist corrosion.
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    492
    Awesome! Thank you!
    10,700 gal IG vinyl
    2 skimmers
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    When I coat my pool deck, I screw the anchors down flush and then coat right over them. I pull them up as I coat and throw them in a container of thinner to clean them while I can still reach them.
