Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: pool levels
    Sep 2007
    North Conway, NH
    23
    pool levels
    Jason, Waterbear, SeanB,
    I filled our pool with town water last week and it has rained everyday since. This year I want to use the BBB method but I'm still a novice at this pool thing and want to make sure I do this right. These are the levels of my pool H2O this morning. I figured out the bleach and baking soda amounts, but I can't figure out when, why or how to use Borox. But I still want your opinions on everything, Thanks!
    TH 0
    FC 0/0
    PH 4
    TA 40
    CYA 0
    Thanks. Luvmypool
    18x5 AG Sand N Sun Vinyl/Metal Frame, 7800 Gal, Changable Filter System.
    Re: pool levels
    How did you measure the PH? Most test kits only test PH down to 6.8. If the PH was actually 4 the TA would be zero, so the PH can't really be 4.
    See this article for suggested levels. Getting some chlorine into the pool and getting the PH up to a minimum of 7.2 are both priorities. After that you can work on your other levels and start doing some reading at Pool School, see the link in my signature or in the sub-heading of every page here.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: pool levels
    Quote Originally Posted by luvmypool
    TH 0
    FC 0/0
    PH 4
    TA 40
    CYA 0
    Thanks. Luvmypool
    Are they the only ones allowed to respond?
    Are you sure those test results are accurate?
    You need to put in enough bleach to raise your FC to 2.
    You need to add stabilizer to reach at least 30.
    Use the pool calculator to get your proper dosing. Have you read the articles on BBB for beginners in Pool School? Also you need a good test kit, if you don't already have one. It's essential for maintaining your pool and the best investment you could make.
    Sep 2007
    North Conway, NH
    23
    Re: pool levels
    Thanks. I used the dipstick method. Someone just bought me the drops test kit but the directions are limited just like me when it comes to all this. Believe it or not, I own a business and do the accounting for 3 other businesses but I just can't seem to wrap my head around this pool level thing. I'll go retest and calculate and add some bleach. And yes, the more help I can get the better.
    Thanks to all,
    luvmypool - Kate
    Sep 2007
    North Conway, NH
    23
    Re: pool levels
    Luvmypool
    Hi Guys,
    Retested with the liquid drops test kit and came up with basically the same #'s. I imput them into the pool calculator and came up with this...
    add 57 oz bleach
    6lb and 11 oz of baking soda
    44 oz of borox.
    I'll let that settle for a few hours and retest.
    Thanks again.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: pool levels
    What pH did you get when you retested? It isn't anywhere close to 4, since pool test kits only go down to 6.8. I'd recommend against adding any more baking soda, as that's going to put your TA around 120ppm, and the borax is going to raise your pH quite a bit. I'm not sure what numbers you are shooting for.
    This is a typical pH testing vial. You match the colors on the right to your water sample
    The yellowest color is pH 6.8, while the reddest at the top is 8.2.
    Guest
    Re: pool levels
    Without a full set of test numbers that don't have bogus values we really can't help you... If you tested your water with a pool test kit there is NO way you would have had a pH of 4!
    Sep 2007
    North Conway, NH
    23
    Re: pool levels
    Luvmypool
    Okay,I only said 4 because the scale didn't go any further and I just pulled that out of my ear! I added bleach, baking soda and borax and the ph went from 6.8 to 8.5, the ta went from 0 to 240 and the cya went from 0 to 100. This is what my levels should be for our pool set up.
    fc 2.4-3.6
    ph 7.5-7.8
    ta 70-90
    ch 50-300
    cya 30-50
    now it seems like I have to lower all that with muratic acid according to the pool school. What do you think? Would it be easier to just drop water out of the pool and ad new to it?
    Sorry to be such a pain in the corn hole.
    Kate
    Sep 2007
    North Conway, NH
    23
    Re: pool levels
    Okay, this morning these are my #'s.
    TH 0
    FC 0
    PH 8.4
    TA 180
    CYA 0
    What do you think I should do? Notice that the ta# went down from 240 to 180 and the cya went from 100 to 0 again. Didn't do anything accept let the pump run 2 hours at a time 3 times a day since yesterday. Please help.
    Thanks
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    Re: pool levels
    TH 0
    FC 0
    PH 8.4
    TA 180
    CYA 0
    WHAT DO YOU THINK I SHOULD DO? NOTICE THAT THE TA# WENT DOWN FROM 240 TO 180 AND THE CYA WENT FROM 100 TO 0 AGAIN. DIDN'T DO ANYTHING ACCEPT LET THE PUMP RUN 2 HOURS AT A TIME 3 TIMES A DAY SINCE YESTERDAY. PLEASE HELP.
    THANKS
    Kate- What are you using for a test kit? I don't know what you are using but your numbers are not accurate. You need to either go to a pool store and have your water tested or have someone do the test with you to make sure you are doing it right.
    It isn't possible for your CYA to be 0 today if it was 100 before unless you drained out all of you water.
    I have to say until you get some more reliable numbers none of us can really help you because we are bound to give you the wrong info if your numbers aren't accurate. Get a better set of numbers then repost them so we can help.
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator , http://www.tftestkits.net/
    11,969
    Re: pool levels
    If you put in the baking soda and borax and immediately tested for CYA I would suspect that is what caused a resulting error.
    Borax and Baking Soda do similar things....so I can't see a reason to add both at the same time....
    Have you read all the articles in pool school? It's frequently advised (except with bleach-the rules are different) to undershoot your target when dosing, so that you don't go past your goal and end up in your situation, having to correct numbers.
    Sep 2007
    North Conway, NH
    23
    Re: pool levels
    I am using a HTH test kit. I'll retest when I get home around 5:00 pm today.
    Thanks for trying to help me.
    Kate
    Sep 2007
    North Conway, NH
    23
    Re: pool levels
    Dear Moderators:
    I'm using the HTH 6 way test kit. I've just tested the water here in sunny NH @ 1:30 pm and here are the results.
    Total Chlorine/Total Bromine Test no color
    (add 5 drops of OTO and invert to mix)
    PH test 8.3
    (add 5 drops of phenel red)
    TA test 150
    (add 5 drops of alkaline indicator and it should turn green and it did, and then add drops of the alkaline titrant until it turns red, it took 15 drops)
    Total Hardness Test 30
    (add 5 drops of hardness indicator and it turned red, then it took 3 drops of hardness titrant for it to turn blue)
    CYA Test
    (fill to 7 ml with water to be tested & then add cyanuric acid reagent to 14 ml line and mix for 30 seconds. Transfer cloudy (mine was clear) water to the CYA tube with black dot on bottom until the dot disappears from top view (mine didn't disappear)
    Is it possible to help me with these figures? I can always drain pool and refill if you guys thinks it's necessary. Sorry to be such a pain about this. I didn't realize how serious the chemical work was for a pool until I sat and read the pool school and all the information you folks have on this site.
    Thanks again,
    luvmypool
    Re: pool levels
    Your PH is too high, you should lower it. You can use muriatic acid or dry acid to lower the PH. Bring the PH down into the recommended range, 7.5 - 7.8.
    Your CYA level is too low. You can raise it with stabilizer/conditioner, available at pool stores or places that sell pool chemicals.
    11,969
    Re: pool levels
    LUVMYPOOL, my responses are in bold italic under your questions.
    Dear Moderators:
    According to the Pool Calculator (see the link in my sig) you need to add 1 qt of bleach (1/3 of a jug of regular clorox), ASAP to get some FC in your pool to prevent algae. This amount will get you to 2 ppm FC. Is your water clear? If not, you need to go higher with the bleach, say to 10ppm which is shock level for a pool with no CYA, which would be about a jug and a 1/3 of another jug.
    PH test 8.3
    You need to go to Home Depot or Lowes or similar hardware store and buy Muratic Acid, 31.45% strength. Add 11 oz and allow to circulate 1 hour, then retest. Don't bother to retest if you shock your pool, high chlorine will give you a false reading. Wait till the FC drops to retest (if you decide to shock)
    TA test 150
    Don't worry about this for now. You can adjust it later when you are more comfortable with the routine of pool maintenance
    You can add calcium later..... this should be about 150 but it's not urgent.
    CYA Test
    You have no CYA. Add 40 ounces of CYA/Stabilizer, sold at pool stores or Wal-Mart. It takes several days for a week for the granules to fully dissolve and register on tests. So don't backwash your filter (if you backwash) and don't retest for another week.
    Thanks again,
    luvmypool
    No worries, and we're glad to help. Just take your time, and be patient and don't rush into anything. YOu'll be fine and the confidence will come. Trust me.
    11,969
    Re: pool levels
    BTW,
    Until you have CYA registering on your tests, you will need to add 1/3 of a jug of bleach each night to keep your FC at 2. You will lose most of it to the sun during the day. YOu have to keep FC in there to prevent algae from taking hold.
    Hope this helps.
    Sep 2007
    North Conway, NH
    23
    Re: pool levels
    frustratedpoolmom,
    Thanks. A few questions though. I want to use the BBB method I've read about, so would I still use the muratic acid and the cya/stabalizer/conditioner? Yes, my water is very clear, but I will go add chlorine right now.
    Thanks again,
    luvmypool
    11,969
    Re: pool levels
    frustratedpoolmom,
    Thanks again,
    luvmypool
    Yes, the BBB method incorporates MA and CYA but it doesn't sound as catchy with those letters attached.... But they are essential to BBB! That and a good test kit.
    Sep 2007
    North Conway, NH
    23
    Re: pool levels
    Hi Frustratedpoolmom,
    This is after adding chlorine last evening and 11 oz MA today and tested 1 hour later.
    still no color
    PH test
    now 7.5
    TA test
    now 200
    Total Hardness test
    still 30
    CYA Test
    Same as above.
    Thanks again,
    luvmypool
  20. Back To Top    #20
    11,969
    Re: pool levels
    still no color
    PH test
    now 7.5
    TA test
    now 200
    Total Hardness test
    still 30
    CYA Test
    Same as above.
    Thanks again,
    luvmypool
    Hi there,
    First the TA. Either this test or the other one had an error, there is no reason why it would go up, especially if you added Muratic Acid, it should drop. Be sure to add one drop at a time and swirl for about 10 seconds in between drops. Count slowly, its' easy to lose count, I have done it several times.
    Your FC is still Zero, so tonight after sunset I would put in 1 and 1/3 jugs of bleach, and then wait one hour and retest. Your chlorine should read 10, if it doesn't add bleach according to the pool calculator and whatever level it reads at. So if it's at 7, put that in the "now" column and then put 10 in the "goal" and it will calculate for you how much bleach to add.
    Save your CYA reagent - you are not going to be able to get any CYA results for several days. Wait until Friday and test it again.
    Does all this make sense?
