Thread: Variable Speed Motor?
    Apr 2014
    FL
    9
    Can I change the speed on a variable speed motor while it is running? I'm speaking about simply flipping the switch on the motor from high to low without turning off the motor. Thanks in advance.
    Re: Variable Speed Motor?
    Yes, you can change speed on a two speed pump with a manual speed switch at any time.
    As it happens, switching the speed switch will turn the motor off for just an instant.
    Apr 2014
    FL
    9
    Thanks just wanted to make sure I didn't damage it
