Thread: Needing to Backwash more frequently after intake/return plumbing upgrade
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Hey all, I have a sand filter question. (all my info is in my signature) the filter holds 100# of sand.
    I recently changed from intex fittings/plunger valves to hayward fittings. I know I have better flow than I used to have and I think my filter may be filtering better because of it.
    What I have noticed though is that I feel like I am having to backwash pretty often. Right now my pool has a leaf net on it so there is nothing really big getting in there on a daily basis.
    I have been vacuuming with my new pool blaster max vacuum so no vacuum junk is going through the filter.
    In the past I hardly ever had to backwash. I usually only did it if I vacuumed.
    Before my plumbing changes my clean pressure was 10psi and I would backwash at 12 or so.
    My new clean pressure seems to be between 11 and 12. (I'm going to call it 12)
    I backwashed on Saturday because the pressure was up again to around 16/17.
    It went back to just under 12 after the backwash until this morning when I checked it and noticed it's back up 13.
    I guess what I'm wondering is, based on the size of my pool and filter and the fact that nothing large is getting in there, how often should I have to backwash my filter? (oh yeah, my pump is still running 24/7 because I don't have a timer)
    When I backwash I usually go for about 1 -1.5 minutes backwash then about 30 seconds rinse. For the first 30 seconds at the most the water is a little dirty looking and for the rest of the time it's clean.
    If my filter is in need of a deep cleaning would that cause the pressure to rise more quickly between backwashes? I don't think I have ever deep cleaned it.
    I'm willing (but scared) to take it apart for the deep cleaning but I was wondering if that affects the time between backwashes or just the effectiveness of the filter itself. It seems to be doing a great job and the pool is crystal clear. I have been vacuuming it every few days with the pool blaster because it's fun. lol
    Thanks for any help or input you can offer!
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    Apr 2013
    North OKC Area
    300
    Re: Needing to Backwash more frequently after intake/return plumbing upgrade
    Sounds like your filter is working great. You're problem is how much water you're asking the filter to clean. A smaller pump, or a 2-speed pump running on low would let you go longer between backwashes. Likewise, a timer and running the pump less often would let you go longer between backwashes. A bigger filter would also allow you to go longer between backwashes but your current one is fine for your pool size. I wouldn't do a deep clean unless there is a problem that calls for it and I don't think your situation calls for it.
    17,100 Gal 27' x 52" AGP steel wall vinyl; 44gpm Cooper sand filter; Hayward 1hp sp1580 single-speed; 1.5" plumbing, 1 skimmer/jet, inline chlorinator.
    Chlorine / CYA Chart | SLAM Process | Chlorine cost/fl. oz calculator
