Results 1 to 19 of 19
Thread: Testing and balancing pool water most important readings
    Pysiek's Avatar
    Apr 2012
    Frankfort , Illinois
    419
    My cousin purchased a house with above ground pool. He called me last night and asked me to help him with the setup. Previous owner keep the filter in garage for the winter. Here is the thing. My cousin is pretty dumb . For example he did not know that skimmer is the section where the water got sucked in to the pump and filter. He don't know where to connect hoses so the water will flow thru the filter .
    Over the weekend I will go to his house and take a look at the pool. He told me the water looks clear because he lift some of the cover and took a bucket of water out of it and it was clear. I believe it is green anyway. But I will go there with my TF-100 test kit and test everything. Probably show him how to slam the pool and explain it a little.
    Over the phone I tried to explain him how he suppose to test the water and what to test for. I only talk about chlorine and he already was confused. I know he will not be able to keep everything in balance so I'm asking you guys. What is most important to keep at balance in above ground pool? I think it is FC and pH. Also what is the easiest way to do it? Should I tell him to use bleach or the tablets?
    What I will tell him have to be really simple otherwise he will keep calling me every day to come and check his water And he is about 30 min. drive from me
    30'x54" Quest Above Ground Round Pool , About 21,000 Gallons , Hayward Perflex EC50 D.E. Filter System 1.5HP Power-Flo Pump , TF-100 Test Kit , Two Hayward Main Drains on the Bottom , Hayward CL200 In-Line Above-Ground Chlorinator.
    77"x77"x21.5" Hot Tub
    Re: Testing and balancing pool water most important readings
    If you get everything setup for him, the only daily maintenance is adding chlorine. Just at the start it is important to get PH and CYA to reasonable values. CH is rarely an issue in an above-ground pool. TA needs to be roughly right, but it can vary quite a bit without problems. PH will need to be checked and adjusted at least occasionally, but not so often if using bleach.
    Trichlor is less carrying, but otherwise is more work in most ways. The PH needs to be actively maintained when using trichlor, and high CYA will eventually become a major problem (though not right away).
    Pysiek's Avatar
    Apr 2012
    419
    He won't understand what TA or CYA is and why it is important to keep it in balance. Even if I set up everything for him and then he will just take care of pH and chlorine will he run into problems?
    Casey's Avatar
    SW PA
    10,444
    I knew my old pool so well, I probably could have gotten away with just dumping an x amount of bleach every other day but the test kit I had was additional insurance that confirmed what I knew my pool needed and was getting.
    If you want to tell him anything, I'd sell him on his own TF100 and a free subscription to TFP! He needs Pool Schooled!
    Pysiek's Avatar
    Apr 2012
    419
    Quote Originally Posted by Casey View Post
    Believe me he will not get anything from it. He almost cried when I told him he can use bleach to keep chlorine balanced. He was like "Bleach??!! The one that you use in washer? Are you crazy!"
    I'm not even sure if he will be able to keep pH at balance. He can only do one thing at a time. I cannot tell him to use more then bleach otherwise he will ask me to do everything for him all the time. I'm not trying to be rude it just I do not have time to go to his house and check his water all season.
    Casey's Avatar
    SW PA
    10,444
    Cut him loose n give him the local pool store's number. Some people can not be taught. He'll either sink, swim or take the pool down!
    Pysiek's Avatar
    Apr 2012
    419
    He will do what you tell him to do. If I tell him put such a amount of this every two days he will do it,but if the process includes different amount then his brain won't be able to process the information. I think he will have the pool for one season only. Unless he will find someone who will help him with it.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    You have it. pH and Chlorine are most important of all. Maybe you can help him a little this season and he can do better on his own next year. Maybe not, but you can hope.
    Essential Links:
    Smykowski's Avatar
    Sep 2011
    3,065
    The TFPC method only works for people who are willing to embrace it, and then take the time to learn. It's nearly impossible to convince someone who isn't willing to entertain the idea of maintaining a pool other than the pool store way. If you mention it, and they don't want to hear it, it's not worth your time. The best you can do is just show them your water later on in the summer when they complain about theirs.
    Pysiek's Avatar
    Apr 2012
    419
    I visited his house over the weekend. Actually the water is not bad. Some green stuff on the bottom but not much. I tested the water for pH and it seems to be about 7.3 -7.4 . Chlorine of course 0. I set up the pump and filter for him but he did not fill the pool all the way up yet. He do a lot of stuff on the house after work and then he goes to his in laws house to sleep (temporary house) so he do not want to leave the water running while he's away.
    I told him to go and get , for now at least, the testing strips. He want me to order him the TF-100 kit. I will but I explained him that he must first learned all the chemicals. And here was another problem. There was his friend there who used to have a pool when she was living with her parents and she say all the time : " go to the pool store and get this and this and after you are done get this and this" . She was so into it that I did not even open my mouth.
    After she left I told him if he want to go and do it as she told him so then I cannot help him because I do not use the pool store product unless it is CYA. And he told me that he will not do it her way because her pool water was never clear so she probably did something wrong.
    So far it looks like he want to learn but I will have to explain everything to him so it sounds easy. First I told him about the CYA , pH and Chlorine. It looks like he got it but still same question "how much do I have to add?". I told him about the pool calc but did not have time to show it to him how to use it.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Is he willing to invest in an SWG?
    Love TFP? Become a
    TFP Supporter!
    Pysiek's Avatar
    Apr 2012
    419
    Quote Originally Posted by zea3 View Post
    Probably not right now. He demolished interior in the whole house and now he will remodel everything his way in the house. So probably short on money. Will SWG make the whole process easier for him?
    Oct 2013
    Chapin, SC
    1,141
    Not really, still have to understand and do all the tests necessary for sparkling pool. It may help him keep up his chlorine levels, but if he doesn't understand the whys, that will fail too.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Pysiek's Avatar
    Apr 2012
    419
    I think I will not even mention the SWG to him yet. Might be too early.
    30,421
    Trying to teach TFPC methods to someone when they don't want to read and learn themselves almost always fails. You are nice to help but time after time we see it as unsuccessful. You are nice to help but the odds of a good outcome are probably against you.
    Pysiek's Avatar
    Apr 2012
    419
    I decided to try to teach him and if he really fails then I will help him with the pool. He have two small kids that I would not like if they swim in chemically unsafe water.
    Jan 2012
    'burbs of Augusta, Georgia
    7,351
    Is he married and can she help him if she is taught?
    Pysiek's Avatar
    Apr 2012
    419
    Quote Originally Posted by YippeeSkippy View Post
    He is married. But I don't think she can help him. She agreed to buy the house only if she won't have to do anything with the pool.
    Pysiek's Avatar
    Apr 2012
    419
    Hahahaha. His wife give up. She called local pool supply store to come over and do everything with the pool. When he was removing pool cover all the leaves dump in the pool. (a lot of them) He was trying to get them out but was afraid to burn the pump because of all the lives in skimmer basket. She have to pay $400 for cleaning and chemical adjustment. They have to provide the chemicals to the pool store guy who will come over and adjust the water.
