Results 1 to 8 of 8
Thread: After 5 days away at work pool is messed up :(
    Feb 2014
    dfw tx
    67
    Pool was running great for past month now I come back after 5 days away and both skimmers and jammed ( the pool one and the one attached to the pump) I clean both of them and fill water into the pool one and turn it on everything seems fine but no water is coming out of the pool side and the skimmer is not sucking in anything. Anything else I can try?
    When I refilled the water the pump sucks all of it in also and the skimmer doesnt get refilled with water.
    16k gallons
    IG "roman style" plaster
    Pentair CCP420 Clean and Clear Plus Pool and Spa Cartridge Filter, 150-GPM
    1hp pump
    Built in 2000
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: After 5 days away at work pool is messed up :(
    What's your pump pressure reading?
    Sound like the impeller might be clogged up with the junk that was in the baskets.
    Feb 2014
    dfw tx
    67
    Pressure is 0 this morning pulled skimmer on pump open to try to snake some wire tp see if it clears but water was boiling and motor is really hot
    16k gallons
    1hp pump
    Built in 2000
    Apr 2013
    North OKC Area
    300
    If water is "boiling" but not as hot as normal boiling water, it would indicate a high vacuum caused by a clogged pipe or closed valve between the skimmer and pump inlet.
    17,100 Gal 27' x 52" AGP steel wall vinyl; 44gpm Cooper sand filter; Hayward 1hp sp1580 single-speed; 1.5" plumbing, 1 skimmer/jet, inline chlorinator.
    Chlorine / CYA Chart | SLAM Process | Chlorine cost/fl. oz calculator
    Smykowski's Avatar
    Sep 2011
    3,065
    Is your water level too low? I guess I'm not understanding what you mean by "the skimmer won't fill back up."
    Just to confirm, is your pressure gauge fully functional?
    Feb 2014
    dfw tx
    67
    Yep something stuck in the pump
    Got all the screws out that I can find but still can't pop the cover to see the impeller. Any trick to it is it glued? impeller spins with hardly any effort.
    16k gallons
    1hp pump
    Built in 2000
    Smykowski's Avatar
    Sep 2011
    3,065
    The impeller should unscrew from the motor shaft if you can't clear the debris from there.
    Feb 2014
    dfw tx
    67
    ok gotcha. I just want to take it all apart just to be double sure since I already have it this far.
    16k gallons
    1hp pump
    Built in 2000
