Thread: Need recommendations for pump/heater efficiency
    schurtj's Avatar
    Jan 2014
    Reynoldsburg, Ohio
    20
    This is such a great forum and I appreciate the input. I have been recently toying with the idea of installing an antique coal/woodburning boiler on my plumbing loop. The thing that worries me is that I have 2" pvc pipe on the loop, and the boiler input/output is a 1". I am not sure what type of harm or stress (if any) ,that I would be putting on the system have all the flow go from 2", to 1" and back to 2" again. My other option would be to feed the boiler from a branch line, but then not all of my water is being heated. I would like to just send all the water through the boiler. Any thoughts on this?
    For what it's worth, I have a Hayward Super pump, a 300lb StaRite Crystal Flow sand filter, a gas heater, and then back to the 4 returns. The pool is 18x36 inground with one floor drain and 2 skimmers.
    22,750 gallon in-ground Vinyl Liner (1 main, 2 skimmers, 5 returns) 16x38 from 4' to 9'
    1hp A.O. Smith coupled to Hayward Superpump 52gpm
    300 lb Sta-Rite Crystal-Flo sand filter
    Hayward Comfortzone gas heater
    Manual Pool Vacuum (yes seriously)
    Re: Need recommendations for pump/heater efficiency
    Welcome to TFP!
    You should almost certainly split the line and have some of the water bypass the boiler. The boiler most likely has a maximum flow rate well below your total flow rate. It wouldn't be difficult to make the flow rate on the bypass adjustable so you can fine tune the system later.
