Thread: solar arc panels
    rickyislandgirl's Avatar
    Apr 2013
    Cedar Lake,IN
    58
    solar arc panels
    Does anyone have any info on this product... Solar arc panels?? just need to heat pool a few degrees.
    thanks
    10,400k, AG 21 round, 1.0HP Waterway pump cartridge filter. TF-100
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: solar arc panels
    Solar pool heating is all about area of the panels, there is no getting around that. While I suspect these small panels can produce hot water thanks to their semi glazed design, that is not exactly what you want to warm a pool, you want total volume of heat. Think of these as trying to heat a bath tub in a cold house with a trickle of really hot water, vs a gushing faucet of warm. For effective solar heating you typically need panels sized at 50-100% of the surface area of your pool, while less than 50% will help some it starts getting like trying to heat a house with a single cube heater.
    Ike
    Apr 2013
    Cedar Lake,IN
    58
    thanks
