Results 1 to 7 of 7
Thread: What should I do?
    SuzyAbbott's Avatar
    Dec 2011
    Hamilton, NJ
    127
    What should I do?
    Just got home from work. Been down pouring all day. Water level is about a half inch below the rim. If I pop off the skimmer cover it starts overflowing. Supposed to rain till tomorrow am. I turned off the filter for tonight. Do I need to go put the cover pump in now to drain some off or can I wait until tomorrow? Grrrr
    24' Sharkline Matrix. Coral Reef Liner. Clearwater II Cartridge Filter. Saltron Retro Salt WaterGenerator. 4x20 Ecosaver Solar Panels, Rover Jr. robot vac. Fiberglass Steps and Lifesaver pool fence/gate.
    Previous pool: 9x18 intex with salt water generator and vinylworks 5x10 deck.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,572
    Re: What should I do?
    I would be inclined to drain it down some to keep water from possibly getting behind the liner.
    SuzyAbbott's Avatar
    Dec 2011
    Hamilton, NJ
    127
    Gotcha. I'll go out after dinner and drain it. Where's my kayak?
    Casey's Avatar
    SW PA
    10,427
    I've gain about an inch of water in the last few days too. Not enough to drain some off the top yet but we got some rain.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Stick a garden hose or the pool vacuum hose in and start a siphon. Hint: feed it in slowly, vertically, so all the air gets pushed out, until the hose is full. Then cap it and haul it out and over the side fast and let go. That'll get the siphone going.
    If you let it overflow, it's going to find the low side of the pool and drain there, which will make that section a mudhole, which will probably cause the low side to sink even more, which will make it overflow even more, and so on and so on until the pool collapses. Siphon it away.
    SuzyAbbott's Avatar
    Dec 2011
    Hamilton, NJ
    127
    The skimmer box was literally overflowing. Gave up on the cover pump and kicked on the solar set up and pulled the return out of the pool and off the bluff behind the yard. It's literally raining as fast as it's draining. Prob 6 inches today. And it's still pouring. Ugh!!!
    We had the low corner issue with the intex. It's so weird now to have an actual LEVEL pool!
    I find when I need to Drain, Ill connect the vacuum hose to the bottom port on the filter and drain from there.... with the pump on low it drains a few inches in just minutes... or if I'm unattended for a spell I turn it off, so there is no chance of something stupid happening like the incoming water gets blocked by a pull toy or any number of crappy endings!
    Quote Originally Posted by SuzyAbbott View Post
    On a cool note I see that everyone is a lifetime member or better, love how everyone gives back to the site that gave us soooo much knowledge! sorry to Hijack just a bit
    24' Round 54" Impulse Ovation AGP, 1.5 HP 2 Spd, 150 Sq Ft. Cartridge Filter, RayPak 130K BTU NG Heater, BBB in full effect!!
    Vist TFT Test Kits --- Visit Pool School ---
    Visit the Pool Calculator
