Thread: Drilling and Tapping Chlorine Injection Port - PVC Shavings
    Mar 2014
    Northern CA
    18
    Hi All,
    I have now purchased everything I need for a Stenner pump based chlorine injection system. I am a little concerned about introducing pvc shavings into my plumbing. A dry run at drilling a piece of pvc yielded a surprising amounbt of shavings. Any way to reduced what gets introduced into my plumbing when I drill the actual pool return line? Hopefully, they'll end up in the pool to be collected by the pool sweep, but I'm not sure.
    On a related note, the Econ T pump I purchased is for "indoor use only" but will be installed with the rest of the pool equipment. Has anyone had luck with a poly enclosure or some other box to shield it from the elements? Does the pump generate heat that would need to be vented? I asked about a "rain roof" but Stenner does not make them for this line of pumps.
    Mark
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Drilling and Tapping Chlorine Injection Port - PVC Shavings
    You could always have someone else hover over you with a vacuum cleaner while you're drilling and tapping. That should minimize what goes inside.
    Can't help with the rest, I'm a jug dumper.
    Jul 2011
    Northern NJ
    92
    I will be installing a threaded T into my plumbing. Purchased at Lowes for a couple of $$$.
    Anthony Pool, 35k gal plaster, DE (1.5hp Ultraflow), Rainbow 320, Dolphin Diagnostic 2001 (Advantage) & Polaris, Retrofitted Anthony mod #20 120v Niche light with Pentair 5G & adapter ring, 70's build / recoped and plastered 1.5 years ago
    22,543
    The best way to keep the shavings out of the line is to put a good bit of pool lube on the bit and drill slowly, cleaning and relubing the bit often. Even if some do get in there, they'll flush out and since it's after all the equipment it'll just flush right out the returns.
    They do need some ventilation, but a cover should protect it.
