Thread: Can't Find Manual For My Pump
    Apr 2014
    Columbia SC
    3
    Hi all,
    New guy here. I'll post an introduction later. I was hoping to get some assistance.
    I have a Waterway Wetend pump. Model # SD-10-1N11MB and it's squealing something fierce. I just started it up yesterday for the first time this year. It was covered all winter, protected from the elements, but it sounds like a banshee screaming.
    I'm fairly sure I need to replace something in it, but I can't find a diagram or manual for this thing anywhere online.
    I was hoping someone here might be able to point me in the right direction.
    Thanks in advance!
    Apr 2014
    Columbia SC
    3
    Re: Can't Find Manual For My Pump
    I went and inspected it a little closer. Sounds like it's coming from in the motor itself, probably a bearing gone bad. I just need to be able to figure out how to get to it and what part numbers to order.
    Thanks again
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Welcome to TFP!
    You generally have to pull the pump off the motor and the impeller off the shaft to get to the seals and bearings. Fairly easy to change once you get there. You can often take it into a pool store and have it changed there if you don't have the parts or time. Saves you a service call.
    Apr 2014
    Columbia SC
    3
    Thanks John! I'll see what I can do. Should I just take the old bearing with me to get a replacement? I typically order parts online, but if I have to deal local, I can do that too.
    Quote Originally Posted by JohnT View Post
    Welcome to TFP!
    SW Indiana
    9,199
    Quote Originally Posted by billm75 View Post
    You can take the whole motor if you want.
    Smykowski's Avatar
    Sep 2011
    3,065
    If you can deal with the pump being down for a bit, once you get in there, you might find a number stamped on the bearing race.
    Otherwise google "pool pumps parts". I bought my bearings from Grainger, but I cross-referenced a part number from a parts supplier first.
