Thread: Reagents
    May 2013
    Chandler Arizona
    78
    Reagents
    I have my TFtest TF100 kit from last year. How long do the reagents accuracy last? Do I need to replace them yearly?
    Intex Ultra Frame 18 x 9 x 52 rectangle. 4545 Gallons.
    12 in Krystal Clear™ Sand Filter Pump w/ GFCI.
    Krystal Clear Saltwater System™ w/ GFCI.
    TF-100 Taylor testing.
    K-1000 Taylor testing.
    38,343
    Re: Reagents
    Depends on how you stored them. If they were stored in the climate controlled house out of the sun, they are likely fine.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,034
    Re: Reagents
    The answer is maybe and that's final!
    I keep my kit indoors and I have no problem using whatever reagents. Some might be over a year old. Who knows? Look at the bottles. If they're not discolored, things are probably okay. And if your readings are about what you think they should be, I wouldn't worry.
    Casey's Avatar
    SW PA
    10,448
    Re: Reagents
    I keep mine under the sink, on a shelf except when I'm using it.
    Re: Reagents
    using last year's "leftovers",, stored in under the bed,,, no problems at all,, powder is a little discolored but works fine
    21000 Gallons I/G,,Vinyl,, 1.5 H.P. Hayward Pump,, Hayward Sand Filter S244T.. Liquidator.
