Results 1 to 15 of 15
Thread: CC 0.5 - should I SLAM?
    astronaut888's Avatar
    Jun 2013
    southeast
    118
    Pretty sure that the answer is to SLAM - however, having not had to do so myself I am not 100% sure
    I have been using TFPC for a bit now with great results
    The following are the Taylor 100 results of a friends pool
    She indicated that she had algae and was "getting rid" of it - and that she uses pucks, powder shock etc....
    I am trying to convert her to TFPC and offered to check her water with my kit - primarily to see if her CYA was too astronomical to start with b/c of her use of CYA containing chlorine products.
    From what I see, she is pretty good with all of her chemistry - all except CC - which, thankfully, I have yet to experience with my own pool.
    She indicated she "had algae" and that the pool is now simply "cloudy" but "getting better" w/ "algaecide and shock"
    From her readings, I feel that SLAM is in order but wanted to run it by the forum first - so, please forgive my rather uninformed question.
    CYA 50
    FC 2
    CC 0.5
    pH 7.2
    TA 80
    vinyl pool with 2yr old liner replacement
    16,000 gallons
    forgot to say - her sample was obtained last night but tested by me first thing this morning for what it's worth
    20K gal, IG vinyl, 1 1/2 HP Hayward Super Pump , 100lb sand, installed 2000 - new liner/filter/pump March 2014
    TF-100 test kit
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    495
    Re: CC 0.5 - should I SLAM?
    Her FC is way low for a CYA level of 50.
    If the pool is cloudy then that is one of the three criteria calling for a SLAM so yes it is time.
    Quote Originally Posted by astronaut888 View Post
    CYA 50
    FC 2
    CC 0.5
    pH 7.2
    TA 80
    16,000 gallons
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Ditto. Her FC should be 4, and that's with clear, stabilized water. Cloudy - "algae" then SLAM away.
    Jun 2013
    southeast
    118
    Yeah - I knew the FC was low and was going to address that with her - but - wanted to check with reference to SLAMing the pool before suggesting it
    Having never done TFPC, I imagine SLAMing may be a bit much to suggest she start with for her to wrap her head around - but, I'm certainly going to try and assist as much as i can!
    thanks for the replies!
    TF-100 test kit
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    I'd take the FC up to 8 to 10 for a day and circulate it constantly to get a better idea if there are no visible signs of algae growth.. CC of .5 really wouldn't bother me.
    Jun 2013
    southeast
    118
    Quote Originally Posted by woodyp View Post
    With my enormously limited (!) novice knowledge, I was kinda thinking that with reference to the CC number - however, was unsure if the fact that the sample was done last night and only read this morning would affect the true reading a bit?
    TF-100 test kit
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,077
    A .5 CC level is the same as zero. It really means nothing. Cloudy water however is a warning sign, but could mean she's got a sand filter taking its time.
    As a starting point, a photo for us to see and an OCLT will tell you if there's anything growing in the water.
    Casey's Avatar
    SW PA
    10,423
    If she is going to fight you on this, let her be once you're done. Any indications that she's going back to the pool store and using sticks/pucks and letting the pool go... Just stop and move on. When she starts commenting on your water, just tell her, I tried to help you and leave it at that. Sometimes our best intentions go unnoticed. Some people just can't grasp the concept. Kudos for you though for trying to help. BTDT and only converted my dad and brother.
    Jun 2013
    southeast
    118
    She hit the pool with 193oz 8.25 bleach last night when she went home - ostensibly raising the FC to 10 provided it was still 2 after the full day - which, it likely was not
    Now running sand filter 24hrs
    Says that water is now clear and I tested FC again for her this morning and am reading 4.5
    CC is reading zero
    That type of an overnight loss would seem to me to indicate something going on - but, I don't really know what the FC was right before adding bleach, nor do I know what it raised to after adding - only what I am reading this morning.
    I'm thinking of telling her that she should consider simply moving forward with TFPC at this point , testing daily and adding accordingly.
    TF-100 test kit
    Casey's Avatar
    SW PA
    10,423
    You need a beginning point and an end point to determine OCLT.
    It will be up to her to join and take control of her pool.
    Jun 2013
    southeast
    118
    Quote Originally Posted by Casey View Post
    absolutely (!)
    she's ready to take control - I'm just trying to jumpstart her in the right direction and hopefully help prevent a horrible algae situation before her Taylor TF 100 gets here
    Without detecting CC , would a present algae situation be unlikely - or is CC of zero and a clear pool not necessarily an "all clear" without a proper OCLT?
    TF-100 test kit
    Casey's Avatar
    SW PA
    10,423
    If you want to be 100% an OCLT is to be performed.
    Apr 2014
    Southern California
    45
    Oclt = overnight chlorine loss test
    ~22,000 gallon inground plaster pool, 1 skimmer, 3 return jets
    Irregular pool sized approximately 19' x 40' 9' deep, Color Splash 3G pool light
    Pentair Clean & Clear Plus cartridge filter (part# 160301)
    1 HP Pentair Pump Model WFE-24 single speed
    Light Blue Pool Cover BBB Method
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    This was my first reaction too. Raise the level of FC and see what happens first. CC of 0.5 is very low. I've had it a couple of times and just raising my FC a bit (I'm supplementing a SWG that isn't running all the time due to low temps), easily dropped the CC back to 0.
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    What Casey said. OCLT is the tell of the tale.
    Divin Dave,
