Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: how long to run my pump
    careingemt's Avatar
    Sep 2013
    PA
    143
    When is the best time to have pump turn on and off. (should I let the sun heat up the pool and then have it set to come on at 1pm and off at 9pm. I do have a solar cover) or is 6 hours enough.
    AG 18 feet accross 52" high pool wall 7000 gallons .... pool math = 7600
    Hayward extreme cartridge filter 100sq feet
    pool is heated by propane Hayward heater
    pool installed aug 12 2013
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    The one water turnover is a myth. Basically it's long enough to keep the water to your liking. Lots of people run for 4-6 hours and are fine with that. I'm one of them.
    Now if you have an SWG that may take longer pump run times to make sure the pool has adequate chlorine. That's not your case.
    There is an article in pool school on how to determine pump run time.
    Jeff
    careingemt's Avatar
    Sep 2013
    PA
    143
    Re: how long to run my pump
    You mean this article
    Pump Run Time
    Conventional wisdom is that most pools need 1-2 turnovers per day. However, studies have shown that most pools need far less run time than that and can usually get away with 3-4 hours of run time per day. However, for two speed or variable speed pumps on low speed, the skimming action tends to decrease so the run time may need to be increased to compensate. The bottom line is to run your pump long enough to keep chlorine at recommended levels and to keep the pool clean enough for your own personal preference.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Yep that is the one.
    Jeff
    careingemt's Avatar
    Sep 2013
    PA
    143
    Test results from 8/25/13
    careingemt's Avatar
    Sep 2013
    PA
    143
    My pool
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Nice pool Fran - hope you recognize that their advice from their tests are a tad off base and they just want you to spend money on the wrong stuff....? Like calcium increaser you don't need to worry about in a vinyl pool....
    Have you purchased your own test kit?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    You don't need the PH increased either. Even though that's an old test. Just an example of things you don't need. Fran is going to get a good test kit hopefully. We've been working on him pretty hard.
    Jeff
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    Why are the test results from last August?
    16k gal, 28'x3.5', Vinyl A/G, 1hp Pentair Dynamo 2-speed Pump, Hayward S160T Sand Filter, Intermatic HB800RCL Digital Timer, Intex 8110 SWG, TF-100 Test Kit, SpeedStir Author: Jesse's Graphical Pool Testing Log
    careingemt's Avatar
    Sep 2013
    PA
    143
    thanks. I have a wal-mart 6 way test kit. Last year I used strips so i'm getting better. seriously thinking of TF-50. I do have a heater if this means anything
    most accurate I had at the time I was using strips to test.
    Quote Originally Posted by pwrstrk View Post
    .... I am confused ... my test results were 7.0 on pic min is 7.2 - max is 7.6 ..... TFP recommends 7.5 - 7.8
    why should I not increase PH
    honestly trying to understand not to be disrespectful in any way
    PH - Acidity/Alkalinity
    PH indicates how acidic or basic the water is. PH should be tested daily at first. Once you gain experience with your pool, less frequent monitoring may be appropriate, depending on your pool's typical rate of PH change. A PH level of 7.7 and 7.8 is ideal, but really anything between 7.5 and 7.8 is doing fine, while levels between 7.2 and 8.0 are acceptable for
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Because you can use borax to raise PH. You can get that at Walmart also, in the laundry isle. Usually PH will raise on its own. You can also take your return jet and point it upwards so the water is breaking the surface. That's called aeration and that will increase PH.
    My PH is usually 7.2-7.4. I don't mess with it.
    Jeff
    11,969
    I was only talking about the calcium. Sorry
    Yes you do want to raise the PH, but as stated, cheaper to buy Borax.
    Ah, on the heater. Check your heater warranty. Some do require a 200-250 calcium level, but if the heater is out of warranty don't worry about the calcium level in vinyl pool.
    The TF-50 would be a great idea.
    So with your 6-way, have you tested the PH yourself?
    careingemt's Avatar
    Sep 2013
    PA
    143
    careingemt's Avatar
    Sep 2013
    PA
    143
    Tonight I will test... very hard to distinguish colors between glass and color of water.... maybe just not to testing
    careingemt's Avatar
    Sep 2013
    PA
    143
    Used to testing
    careingemt's Avatar
    Sep 2013
    PA
    143
    Did not know I could raise Ph with aeration. Thanks. Idea to follow
    careingemt's Avatar
    Sep 2013
    PA
    143
    Can do this to airate water
    careingemt's Avatar
    Sep 2013
    PA
    143
    If I turn up return solar cover spins
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    It's best to do it with the cover off. You want the water to break the surface.
    Jeff
  20. Back To Top    #20
    careingemt's Avatar
    Sep 2013
    PA
    143
    Cool...... will post link later.... can I come off of main.return feed to add PVC to aierate
