Thread: Pool Light
    Apr 2014
    california
    1
    Unhappy Pool Light
    Hi , i have a jandy halogen that i am trying to replace with a 12 v led . When i was trying to pull the wire it is extremely difficult and i tried water and soap and flushing with brass etc .. it does not work when i looked at the niche i saw a lot of calcium deposits that i have chipped away but i see something black flush with the wire and the pool hole I am thinking it is expoxy .... i know the pool builder who installed this in the first place ... what are my options is this easy to remove , if i need to drain the pool do i need to relieve the hydrostatic pressure if i let the water down about 2.5 feet .. it is a 7.5 feet deep pool...
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Pool Light
    I have no experience with this Sam, but I wanted to say Welcome to TFP!
    Essential Links:
    Re: Pool Light
    Epoxy at the back of the light niche usually means the conduit leaks. It should be possible to remove it, but it won't be easy.
