Thread: Hayward E command
    Apr 2014
    San Antonio TX United States
    13
    Hayward E command
    Want to add this to add automation. I have a pool only and want to use it to control my colorlogic led light, my waterfall valve, my bubbler valve, my hayward tristar vs pump, and my booster pump for my cleaner. Is this possible? And how? The vs pump and light makes sense, but im confused on the rest.
    Re: Hayward E command
    Welcome to TFP!
    That is a very standard use of the E-Command, everything is described in their manual. You will need at least two valve actuators in addition to the E-Command to turn the waterfall and bubbler valves.
    Apr 2014
    13
    Thanks, my pool builder (Blue Haven) doesn't seem to be familiar with the system. I am debating just installing it myself.
    If you have experience with line voltage wiring it is a fairly simple install.
