Thread: Cooling Effect of Spa Jets
    Apr 2014
    california
    1
    Hi All,
    This goes out to the math nerds.
    Could you help with calculating the heat loss from running spa jets. Averages are fine, i.e., flow, nozzle size, nozzle number, water temp, air temp, etc.)
    Thanks a bunch!
    p.
    Casey's Avatar
    SW PA
    10,448
    Re: Cooling Effect of Spa Jets
    Welcome soaker... I'm sure someone will help you. Me? I hate math! I'll sit in the back of the class for this one!!!
    Mar 2007
    San Rafael, CA USA
    12,082
    Welcome to TFP!
    That's not an easy calculation. It would be far easier for you to just measure the temperature drop per time when the jets are running. The temperature drop might be proportional to the temperature difference between the air and the water so you could calculate for other conditions accordingly.
