Thread: What is the booster pump for?
    I saw a booster pump next to the main pump but never used it for 4 years living here. Not sure what is it for? Please educate me.
    30,419
    Re: What is the booster pump for?
    It is used only if you have an auto-cleaner that requires a booster pump. Perhaps that cleaner is long gone?
    Correct. There's no auto-cleaner. Thanks.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to the forum!
    If you don't have a pressure cleaner you might consider a robot cleaner. I don't see details about your setup, so you might add that to your signature so we can make suggestions or help with problems more easily.
    Essential Links:
    May 2013
    Fort Lauderdale, FL
    423
    There should be a return in your pool that is is plumbed too. Fire up the pump and see which one. That's the one the vacuum goes on. Polaris 280's are popular and require a booster pump.
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    happyheathen's Avatar
    Sacramento CA
    225
    This rig has an (unused) booster - it also has an open/shut ball valve on a 1" PVC line - that valve is for the booster.
    Why someone thought they needed to both turn off the booster AND close the line, I don't even WANT to know, but there it is.
    After the valve, it goes to a female threaded (1 1/2" NPT) fitting on the wall.
    In this install, it is the only return with a threaded fitting.
    If you have a small-diameter valve, check it when testing a the booster.
    Dave
    Sacramento
    1980's 15,000 Gal IG Plaster; 1 1/2 hp Hayward Northstar; Hayward Swimclear C3025 Cartridge Filter (325 sq ft, nom.); Pentair Legend; Polaris PB4-60; Equipment 40' from pool. p.s.: it's an aye-aye.
