Re: Pentair Control Panel tripping 30 amp breaker
Posts merged. Please never ask the same question in more than one place. Thanks JasonLion
Try turning everything off, both pump and control panel, and then back on again and see if that does anything. Also, make sure you are not in service mode on the pump.
There is a somewhat rare problem when a nearby lightning strike burns out the communications chip on the pump. If that is the issue there is nothing you can do except to replace the "drive" unit (electronics box with the controls) on the pump, which is fairly expensive.
