Thread: aqua rite t-15 HIGH SALT reading with scary red light!!!!
    Apr 2014
    tampa, fl
    6
    when first powered up it shows around 5100, then display changes to 'HI'. last reading was around 2700 so i added a bag. its a 10,000 gal inground pool. one bag wouldnt raise this high. recently cleaned the gen, it looks brand new. any thoughts? also, what would be the symptoms of a bad cell? thanks
    10,000 gal pool, five years old, salt pool for last four years. hayward aqua rite t-15, hayward northstar pump, solar heat, de filter, tampa, fl.
    Re: aqua rite t-15 HIGH SALT reading with scary red light!!!!
    Welcome to TFP!
    If you added salt in the last 24 hours, turn the SWG down to 0% and run the pump until it has been 24 hours since the salt was added. Sometimes salt doesn't fully mix in right away. It is possible that the SWG got a dose of high concentration salt and just needs some more circulation to normalize.
    Another possibility, if salt was more than 24 hours ago, is something inside the SWG cell shorting out the plates. Take the cell out at do a quick visual examination and see if any of the plates are touching each other or there is some debris bridging across them.
    38,262
    Welcome to TFP!!!
    One sign of a failing cell is when it starts to read lower salt level than reality.
    Have you independently tested the salt level?
    Did you turn off the SWG for a day after adding the salt so high salinity water did not pass through the cell?(I think this could damage the controller)
