Thread: Spa Side Switch Rubber Membrane Replacement?
    Oct 2013
    Brentwood, CA
    8
    The switches seem to work fine but, the rubber membrane covering them is oxidized and badly cracked. I've done some searching and a replacement (for the rubber part not the whole switch) seems unavailable. If anyone has come up with a fix for this I'd sure like to hear from you.
    Doug
    Pool Type - IG Plaster
    Pool Size - 36 ft. X 14 ft. ~15k gal.
    Cartridge Filter - Purex CC320P
    In Floor Cleaning System - 5 Port Valve, CareTaker 99 Cleaning Heads
    Control System - AquaLink RS6
    ps0303's Avatar
    Jul 2011
    FL
    3,710
    Re: Spa Side Switch Rubber Membrane Replacement?
    You have to replace the entire button and cable. No other options. Unless of course you can add a wireless antenna and use a wireless remote.
    Paul
    http://www.gastekservice.com If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - http://www.youtube.com/c/Gastekservices
    Oct 2013
    Brentwood, CA
    8
    Thanks Paul, that's just what I was afraid of. I guess if it starts misbehaving, I can disconnect it from the AquaLink controller and live without it for a while. We're planing a major pool remodel this winter and that would be a good to replace it.
