Thread: Pump Basket Issue
    May 2013
    Tulsa, OK
    83
    Pump Basket Issue
    OK,
    We have opened the pool and going thru the cleaning and set up process now. We got a bunch of debris and leaves from removing the pool cover dumped into the pool. Water is clearing and continuing to scoop and net all leaves and large debris out from the darn neighbors tree.
    Well wife decided to help out and hook up the cleaner... well it ran for about 4 hours before I caught it.
    -When I caught it, the pump was running but the auto vac was not moving or operating. very little return pressure
    -I turned everything off, removed the hoses and the vac assembly
    -There had been water discharge from somewhere, (nighttime) so I could not see from where.
    -left everything off until daylight.
    -Could not find any visual or obvious areas of leaked or malfunction or breakage.
    -Pump strainer basket is full of debris and ****.
    -pump will turn on and has a decent return pressure at eyeball (just checked making sure everything was working)
    -when running still no signs of leakage to be seen
    **What's safest way to clean out the strainer basket, when I remove the lid it starts shooting water everywhere. I do not have a valve in place to isolate the pump from the intake skimmer.
    ** What could have caused there to be water discharge around pump and equipment. Is there a pressure relief? pop-off?
    Any advice would be great, hope we didn't break anything or tear anything up.
    12x24 Doughboy. 8700 gallons~ 2 HP Dyanmo Pump~ 26" Sand Dollar Filter~TF 100 test kit~ Zodiac Ranger AGP automatic cleaner.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: Pump Basket Issue
    Is the water actually "shooting" out of the pump basket or just...........flowing? Is the pump off when doing so?
    May 2013
    Tulsa, OK
    83
    I haven't completely removed the lid... When I turned it to remove it water was coming out at a pretty high rate. I immediately closed it as not sure. The pump is off during this process.
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    I have little screw in plugs for my inlet and return. I now have standard 1.5" hayward fittings from leslies and the plugs were only $4.99. I don't have a "real" skimmer though so my intake and return are identical fittings. It seems like there should be a skimmer plug available though.
    Before I had my new fittings I had the intex plunger valves. They were old and didn't seal all the way so I know what you're talking about with opening that lid and having water flow out.
    A hint for the lid, once you get to removing it if it has an o-ring make sure you lubricate it before you screw it back on otherwise they get really hard to open!
    I'm sure someone with a "real" AGP will be here to help soon!
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    Oct 2012
    Central Ohio
    180
    As mentioned above these work pretty well.$10-$15 for 2 @ Lowes,home depot,ACE
    http://images.lowes.com/product/conv...53334011lg.jpg (plumbing test plug)
    Just find the correct size for your skimmer hole and your return hole. Just put them in and snug up the wing nut,no need to tighten them super tight.
    If you can't find a test plug for your return try a rubber stopper,the kind you would use for a bath tub or sink.If you can't find one of those have someone hold a rubber ball over the return hole,it won't be perfect but it will work.
    Rob
    Cozumel AGP 24' 14,700 gallons
    Pentair Dynamo 1.5 hp pump
    Sta-rite Cristol-Flo II 2.3sq.ft. sand filter
    SWCG,Uni-bead liner
    Borates
    TF-100 Testkit....$68,cheap insurance for a trouble free pool season
