Thread: 2 speed pump and heater with no automation
    Aug 2011
    Middle TN
    83
    So we're getting ready to start on the electrical of our pool in progress and I'm not sure if I'm going to manage to work the automation into the budget or not. Without automation what do I need to control a Hayward heater( it has a built-in display) and a two speed pump? Maybe the same question about 2 Hayward colorlogic led lights. Do they have a separate controller or just need a switch?
    If I do manage to get an automation system like the Hayward pro logic, I guess I need 2 relays for the pump and either one or two for the lights, and one for the heater??
    It doesn't seem like the prologic panel has a main breaker, does it need an external main breaker?
    Thanks for the help.
    18 x 36 Vinyl Inground, Coverstar Cover, 2 speed Pentair Pump, Hayward 425 Sq Ft Cartridge Filter, Hayward Heat Pump, Prologic PS8, T-15 Salt Cell, 2 Colorlogic LED lights, TF-100 Test Kit
    38,301
    Re: 2 speed pump and heater with no automation
    For the pump you would just need a timer and a switch to manually select speeds. The lights would just need a single switch (I am not sure how those lights work though, by bulb changes color by cycling the power). The heater would control itself.
    The Prologic has a built-in breaker panel, with only 8 slots, so no real need for a main breaker usually, but you could wire one in. The pump would use 2 relays and the light a 3rd, the heater would not need a relay.
    To control the lights, I think you need at least the ps4, the p4 may not be compatible.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Is there a spa attached to the pool? If so, then you would probably have a need to automate your valves, maybe. Hayward does have a entry level automation system but it would require you to have a separate electrical box to hold the breakers. I'm sure though that your builder has already included a panel with built in clock timer so then you would just add the Hayward controller.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Aug 2011
    Middle TN
    83
    It does not have a spa attached, so maybe I don't need any automation?
    38,301
    Probably not. I got mine because I was adding SWG and wanted solar valve control and wanted the pump to automatically change speeds for solar.
