Results 1 to 7 of 7
Thread: Pool Liner
    Apr 2014
    Bellmore, NY
    8
    Pool Liner
    Hi -
    I am currently contemplating a new in-ground pool. One PB is willing to give me a steel-wall, vinyl lining with sand (and only sand) under the liner. The other PB is going with concrete-wall, vinyl lining with vermiculite. My questions is the following: Is a sand-only floor base ok for an IGP? I heard of footprints/other indentations being made as people walk - is this true? In addition any pros/cons of steel-wall vs. concrete-wall (I am in NY). The pool would be a 20 x 42 kidney shape. Thanks.
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    Re: Pool Liner
    Sand can compress and leave footprints. We have vermiculite. It does not dent. Steel can corrode, especially if you have a saltwater pool and some of that water leaks to the walls. There are probably other pros and cons, but that's all I know.
    All other things being equal, I would probably go for the concrete wall, vermiculite floor.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    Apr 2013
    Central Massachusetts
    174
    Re: Pool Liner
    People have 40 year old+ concrete walled pools. Not so sure about steel. We went with concrete (it was similarly priced against steel and cheaper than poly walled).
    26,000 gal 18x36' IG Vinyl Pool - Hayward S244T Sand filter - Hayward Tri-star 2-speed 1.5HP pump - Goldline Aqua Plus SWCG and Controller with Tcell-15 - Aquacomfort 125K BTU Heatpump - Hayward Color Comfort 4.0 LED - Zodiac MX8 suction cleaner - TF100 test kit
    My Build thread
    Apr 2014
    Bellmore, NY
    8
    Re: Pool Liner
    Thanks for the reply - Any worries of having a concrete walled pool chip/replaster etc.?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Pool Liner
    It shouldn't need plaster if there's a vinyl liner, right
    Why not steel or plastic walls and vermiculite bottom? That's a very common combination, and it's odd that neither builder suggested it.
    Mar 2014
    Canada
    14
    Re: Pool Liner
    I've taken liners out of 25+ year old pools and seen steel walls that have no rust and others that are covered in it. It depends on how you look after your pool. If you get a leak in your liner or pool lines and let it go for a period of time your going to get corrosion be it salt water or chlorine. I build mainly steel walled vinyl pools, I would assume a concrete walled pool would cost a bit more. I build on ground pools with sand bottoms and they hold up well, but its true over time you will get foot prints and some dents in the bottom. The only other thing with a sand bottom is if you get a decent size leak or have a ground water issue it can wash away the bottom.
    Apr 2014
    Bellmore, NY
    8
    Re: Pool Liner
    There seems to be something against vermiculite with the contractors I have spoken with. One suggested a sand/concrete mix -- is it worth it?
