Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Which robotic cleaner to choose?
    Jul 2013
    Oklahoma
    33
    We have a 16' x 36' inground pool with a 6' deep end. Currently we have a Polaris 380 and, although it does a great job of cleaning up large debris it leaves a ton of dust patches throughout the pool. We have wasted a ton of water over the past two years by constantly needing to vacuum the bottom to get it cleaned. And with water restrictions now becoming the norm in our area, it has gotten expensive just to clean our pool.
    That being said, I have convinced the wife to save not only money in water, but also to save me from wasting several hours a week to get our pool cleaned is to get a robot to help us out. I have read reviews of various cleaners, but now I come to the experts for advice. As stated above, its not a huge pool, but my only hold up is the fact that the floor is angled in the deep end and I am worried about choosing a cleaner that won't be able to climb the angle.
    We have looked at an Aquabot and a Dolphin. I am leaning towards the Dolphin Deluxe 3 due to cost ($499), but worry if it will climb the angle and clean the deep end well. We are not looking to break the bank, just want something that will work effectively. Any advice appreciated!
    20,000 IGP, Vinyl Liner, Hayward pump, Hayward sand filter, RayPak RP2100 Digital Heater.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Which robotic cleaner to choose?
    All I can say is I have been happy with my two Dolphins, I can't comment on the specific model though
    Ike
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    I would think that either of them will climb the angle easily enough.
    Couple things you might consider before making a final decision which in my decision making process, were important factors in making a selection.
    1. Do you want your robot to climb and clean the walls?
    2. Do you want your robots cord to be tangle/ kink free?
    Quote Originally Posted by dconner View Post
    Divin Dave,
    May 2013
    Fort Lauderdale, FL
    423
    Why not try the sand/silt filter bag for the polaris? Save yourself $400, it's a good model. They make all kinds of bags for it...
    Add a tail sweep pro if you don't have one. It stops the water from shooting out of the pool and helps stir up the sediment so the pool filter will get it.
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    I have a Polaris 280 and it does great with all stuff. That little cleaner is a life saver! Rarely do I need the regular vac.
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    Jul 2013
    Oklahoma
    33
    Quote Originally Posted by zimm View Post
    I have a sand/silt bag, but it doesn't pick up the dirt that gets in our pool. I can watch it drive over the top of the dirt and the watch the dirt blow though the top of the bag. I have read about people putting pantyhose in the bag to help with filtration. I haven't tried the tail sweep pro, but my current tail pushes the dirt around pretty good, but for some reason it never gets far enough to get filtered out before settling back down to the pool floor.
    Quote Originally Posted by Divin Dave View Post
    The only thing I am concerned with really is the floor to be cleaned. The walls would be nice, but I can brush and clean those off every few days with no problem. And I would prefer a tangle/kink free. Basically you are telling me to go up to a Deluxe 4? I just don't know if I can justify spending over a grand on a pool cleaner. Any other models recommended that would be more in the $500 price range?
    May 2013
    North East Ohio
    959
    I am in the same boat as you....struggling to spend $1K - been looking at these models...what do the experts think ?
    http://www.amazon.com/dp/B00CA4U4ZU/...I1MST14A7JZJM8
    This one says above or in ground - plus I like the price point
    http://www.amazon.com/dp/B002B8W3HW
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    May 2011
    Bensalem PA (Philly Suburbs)
    82
    I'm not an expert, but in shopping around to buy one for myself the past couple weeks, I decided on a Dolphin Primal x3 for $600 (basically a DX3 with cartridge filters it looks like, one of their "custom" variations I guess). http://www.backyardpoolsuperstore.co...-_p_24208.html
    I'll let everyone know how it goes when I get it and throw it in my pool this weekend
    18' x 38' x 52" oval AGP with 6' deep end (foam on the walls, preformed coving, and Happy Bottom floor padding)
    Pentair Optiflow 1 HP 2 Speed pump
    Pentair cc200 cartridge filter
    Pentair UltraTemp Model 110 BLK 108,000 BTU Heat Pump
    2 Intex SWG's (copper unplugged)
    Sep 2012
    Houston,Tx
    55
    I read good things about the Aquabot Breeze 4WD. I am about to build a pool and I am debating on which robotic cleaner to get.
    Jul 2013
    Oklahoma
    33
    Quote Originally Posted by Schumacher View Post
    I just saw this one. Anyone else have any history with this cleaner? Will it clean the small particles as well as the other robotic cleaners?
    Sep 2012
    Houston,Tx
    55
    http://www.troublefreepool.com/threa...HE-AQUABOT-AWD
    If you do a search there is quite a bit of info about it. So, far I think it is the one I am going with.
    May 2013
    North East Ohio
    959
    Ouch $800 - dang these guys are expensive.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    http://epicpoolsupply.com/dolphin-nautilus.php
    http://www.poolsupply4less.com/Haywa...0-p/rc9740.htm
    both of these have pretty good reviews on Amazondotcom and are wayyyy less than 1000 dollar ones.
    I originally bought a sharkvac. it worked great IMO. I liked it a whole lot. My friend came over to see it and he loved the thing too and wanted one, but he dont do internet because he wants to see and touch it first. So after him bugging me, I sold him my sharkvac and got me the dolphin nautilus which I considered a slight upgrade. Have only used the dolphin a few times so far, and it works great too.
    The sharkvac does climb the walls a bit, even though Hayward says it doesnt. The cord is a nice one, but its not 100 percent kink free. Overall though, its a good machine IMO.
    The Really Nice thing about the sharkvac, which for me over-rode the kinkless cord, is you dont have to turn it upside down to remove the filters, and dirt doesnt spill back out when its pulled from the water. The filters remove from the top, which is a awesome feature.
    I would recommend either of these cleaners.
    Divin Dave,
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    I've got a Smart Pool Nitro NC22 can be had for about $400. You might find it on sale for $300.
    I've done a review here:
    http://www.troublefreepool.com/threa...ighlight=nitro
    and here's a link to a movie I made while it cleaned the pool
    http://www.troublefreepool.com/threa...-into-1-minute
    May 2013
    North East Ohio
    959
    Quote Originally Posted by bobodaclown View Post
    Do you think this unit would work UNDER a solar cover ?
    Also, is this the same unit ?
    http://www.yardandpool.com/smartpool...FQmSfgodfWMABQ
    morrodds's Avatar
    Aug 2009
    Leona Valley, CA
    10
    Quote Originally Posted by toofast View Post
    I'm returning the Aquabot Pool Rover Hybrid Robotic Pool Cleaner to Amazon. It would stay in the deep end most of the time and leave the shallow end dirty. The filter bag passes dead algae and silt leaving me with a cloudy pool. I tried the several remedies suggested, to no avail.
    Guess I'll try a cleaner with a cartridge filter so I don't need to backwash my sand filter as often.
    Martin
    17k gal., sorta IG vinyl, 1.5 hp pump, 21" sand filter, Shark robotic cleaner.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I'm about to do a post on it, but I just got a Dolphin Supreme M5 this week and I am highly impressed. As luck would have it, my brand new pool got trashed with a huge dust storm, and high winds for several days following the initial fill. This, coupled with dirt all round my pool really did a real number on it.
    I knew dust would be an enemy, and this is the reason I got the M5 with cart filter options. The first run of thirty or so minutes filled the carts more full of dirt than this picture that was taken after two full cycles. After about three of those cycles, I can hardly find dust in the pool. Strangely, the dirt seems to just stick to the bottom and not vacuum up easily at all. We kept brushing to the main drains with some result, but the M5 swept things right up. How well it worked is simply amazing to me. I am so glad I went with this instead of a pressure cleaner setup I was originally planning.
    The advice I offer is the same that was given to me. A robot is better than a pressure cleaner for more than one reason, and $$$ equal cleaning power. This may be the single best piece of advice I got for my entire pool build and it wasn't from my builder either.
    Essential Links:
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    I have the dolphin nautilus but only for a few weeks now.
    It works great. What it doesnt "exactly" do, is crawl sideways along the water line very far. It might go about a foot or so, but it tries hard. The fact that the nautilus doesn't have the float handle is why it wont do that. As far as I can tell, the Only difference between the nautilus and the Dolphin Triton is the float handle.
    This is a very good price point for this cleaner IMO.
    You can get this cleaner and Epicpoolsuppliesdotcom for 599.
    Divin Dave,
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    man thats a lot of dirt! I have been there too! The robot sure makes keeping the pool clean just sooo easy! Put it in, sit back and let it do all the work! I love my Dolphin!
    Quote Originally Posted by Brushpup View Post
    Divin Dave,
  20. Back To Top    #20
    Jul 2013
    Oklahoma
    33
    I found a decent deal on a Doheny's 4WD powered by Aquabot. It is scheduled to be delivered on Tuesday. I will post more about it when I get to put it into the water.
