Thread: Severe rust stains
    tbone2's Avatar
    Apr 2014
    Hinckley, IL
    14
    Severe rust stains
    So I have been slowly cleaning my 3 year neglected pool. SLAMing and getting the final debris out of the bottom. It's been slow going as I have a vinyl liner and there's some bricks and sharp debris so I've been very careful. Here's a photo of the progress.
    Attachment 28754
    I will try to get a close up photo in the morning, but there's a decent bit of rust staining. One spot specifically where I pulled a rusted bike out of the pool. Most in the photo is dead algae, but in the lower left of the photo I'm sure is rust staining from right where the bike was pulled out. Scrubbing with the brush or vacuum doesn't change it at all.
    A couple questions. Does rust staining like this cause any actual damage to the liner? I've read some remedies on the forum to get rid of rust stains. The worst section is somewhat substantial, 2'x4' with the amount varying stains throughout that section. Is there a good way to get that much area clear?
    18'x35' inground vinyl. ~26k Gallons
    1HP Hayward Super Pump. Jacuzzi 250L sand filter. No additional water features.
    Foreclosure pool, 3 years no use. Yes, that is a bike I got from the bottom.
    TFT-100 Test Kit
    30,431
    Re: Severe rust stains
    The rust may or may not be somewhat permanent. At the least, you will be able to minimize it.
    If it was my pool, I would break up the work into two jobs....
    1. Rid the pool of all the algae stains and debris and get your water balanced correctly.
    2. Attack the rust stains with an AA treatment.
    tbone2's Avatar
    Apr 2014
    Hinckley, IL
    14
    Ok. I'll work on getting the water balanced. Here's that up close picture I promised as well. This is probably the most severe spot in the entire pool.
    TFT-100 Test Kit
