Thread: test kit for Canadians?
    Jan 2013
    Southwestern Ontario, Canada
    30
    Looks like the TF-100 can't be shipped to Canada. Is there a way around this?
    If not, can someone recommend a kit that can be shipped to Canada.
    I read the K-2006 is comparable, but it's $144.
    Right now I just have the cheapo kit with chlorine and ph drops.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: test kit for Canadians?
    The problem is there is an exclusive distributor for Taylor test chemicals in Canada, only way around is to get one across the border yourself.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,777
    Just o you know, if you happen to live close enough to Port Huon there is a company there who has mailboxes you can rent for this kind of purpose. Don't know the name but if you googled it with "port Huron" maybe you'd find it.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    38,305
    There are a lot of threads about this if you search. You are stuck with either buying the expensive K-2006 you found, or somehow importing it yourself.
