Thread: Pool Skim Help
    Dec 2011
    Charleston, SC
    100
    Pool Skim Help
    Hello,
    I was wondering if anyone might know of a possible way to attach the Pool Skim to a straight pipe...as recommended here:
    http://www.poolskimusa.com/install.htm
    I have an older pool with slanted 1" diam return pipes....can I use the Polaris 1" stub pipe connection recommended by PoolSkim or do I need to have a pipe that return straight on perpendicular to the wall? Also, is it just as easy to find a pvc adapter that can transition a straght 1" pipe to a 1.5" threaded connection? I've looked but it seems none are made to insert which is what I need since the pipe in enclosed in the concrete wall. Thanks in advance for any comments or advice!
    This is my original post...http://www.troublefreepool.com/threa...185#post625185
    IG Gunnite Pool Size: 25K gallons (20 x 40, 3'6" to 6" depth) with 2 huge Baker Hydro cartridge filters under the skimmer baskets on the suction side, 2 mech timers
    BRAND NEW PLASTER! Quartzscapes/Diamondbrite, Newer Polaris 280, Brand New Hayward Maxflo VS, Brand New Pentair Intelichlor
    I will conquer the black algae this pool season!!!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: Pool Skim Help
    If you are still having trouble connecting the poolskim to your pool, please post a picture of your return and we will try to help you find a solution.
    Love TFP? Become a
    TFP Supporter!
