Thread: Pollen stains on my vinyl pool
    Apr 2014
    Palm Bay, FL
    1
    Hello,
    Please help!!! This season has been horrible with the tree pollen. My pool got pollen at the bottom of the pool, I put the vacuum on and it picked up the pollen but now I have these mustard looking stains/spots all around the edge of the bottom of the pool and on some spots in the middle. Is there anything that I can use to remove the stains? I've used a brush to clean it and nothing happens. I'm thinking chemicals is my last resort.
    Thank you in advanced...
    Vania
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Pollen stains on my vinyl pool
    Welcome to TFP!
    Chlorine will eventually get them. Higher levels will get rid of them more quickly.
    Casey's Avatar
    SW PA
    10,424
    And don't forget to brush your pool! More than likely, it stained because it sat on the bottom too long. With elevated chlorine levels and simple brushing, they should disappear in no time.
    Welcome to TFP!
