Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Green Pool
    Question Green Pool
    i need some advice quickly, i have a very green pool after uncovering last week and not being able due to weather to get it up and running at that time. so today it is a big green mess and getting worse by the day.
    we have storms for the next 2 days coming so i can not hook up the filter and pump until after that. my concern is, if i go ahead and get it hooked up and filled back up and running and get my bleach in it, how bad is it going to be for the sand filter system? also, should i replace my sand this year in the filter, got the pool in July of 2012, so it has only been 1 1/2 seasons.
    AG 24' ( Columbia PL30-6 sand filter), 2hp 2 sp pump, cholorine, Tennessee
    Taylor k- 2006 test kit
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Green Pool
    No need to replace the sand. Sand filters are the easiest for clearing swamps, IMHO. You'll be fine. Did you read the article in Pool School for instructions on clearing it?
    Casey's Avatar
    SW PA
    10,418
    Re: Green Pool
    Hook up the filter, top off the pool and SLAM away according to Pool School.
    What kind of test kit do you have?
    Re: Green Pool
    Don't have a test kit yet , what do you recommend.
    38,235
    Re: Green Pool
    The TF-100 with xl option and SpeedStir. See the test kit comparison article in Pool School.
    Casey's Avatar
    SW PA
    10,418
    Re: Green Pool
    Also, it would be helpful if you could add your location to your profile.
    Jun 2013
    Fontana California
    56
    Re: Green Pool
    what jblizzle said above.
    Last year before I learned about this site I too had a green pool and was trying to clear it up for Mothers Day. I hired a pool company to perform their Green to Clean service for $125.00. The pool service came out, walked around my pool sprinkling "magic dust" in it and left promising to return in a few days. They did this three times before it finally cleared. Took about 2 weeks. I thought it was money well spent but to my surprise within a couple of months I (well another pool service that I was paying for) was fighting either a green or cloudy pool off and on until the police department came to my house and forced me to either drain my pool or clear it up within 3 days.
    The point I am trying to make here is if I would have found this site like you did when I first had the problem, bought a TF Testkit and read pool school I could have cleared the pool myself and saved myself a lot of money and spared myself a great deal of frustration.
    14K Gallon IG Gunite Pool built in 2005, Century Centurion 1 1/2 HP Pump
    Pentair Clean & Clear 420 Sqft. Cartridge filter, MiniMax Pentair NT Heater, The Pool Cleaner
    Taylor K-2005 test kit with Taylor K-1515-A FAS-DPD Chlorine Test. SpeedStir
    Re: Green Pool
    What does the SpeedStir do and is it necessary?
    38,235
    Re: Green Pool
    It is not necessary, but makes the testing faster and easier by stirring the water for you so you do not have to swirl with one hand and put in drops with the other. This helps a lot with the CH test or it you are having to SLAM and put in 40+ drops.
    Casey's Avatar
    SW PA
    10,418
    Re: Green Pool
    The speed stir is awesome!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Green Pool
    I do love the speedstir but the bottom of the chlorine only vial from the T100 kit doesn't love the stir bar.
    Isolated Spa - 345 Gallons
    Cool Re: Green Pool
    Quote Originally Posted by Casey View Post
    I have my pool topped off and pump running, put in 2 gallons of bleach last night and ran pump for a couple hours, did not want to run it all day today with me being at work and could not back wash as needed.
    Have ordered a test kit TF-100, which should be here next week. Question of the day is, how do you test really green water? It is like a swamp, can barely see the bottom of pool. Should I keep running pump and backwashing as needed and keep adding a gallon of bleach each day? Your advice is greatly appreciated.
    Casey's Avatar
    SW PA
    10,418
    Re: Green Pool
    You should be fine running your pool while you are away.
    I've never tested really swampy water but I don't anticipate you having an issue with testing. Just read the very simple directions that come with the kit and if you have problems, post them here and we'll get you sorted!
    Re: Green Pool
    Ok, recd my Taylor k2006 kit, here are my numbers.
    Total chlorine .8
    FC. 2.0
    PH. 7.9
    Alkalinity 100
    Calcium hardness 110
    CYA. 70
    How does this sound and what do I need to add.?
    38,235
    Re: Green Pool
    Step 1, order more FAS-DPD reagents since you did not follow our advice and get the TF-100 with xl option. You will quickly run out before the pool clear.
    Total chlorine can not be greater than free chlorine, so check that.
    Your CYA is marginally too high. You need to SLAM the pool which would be a little easier if your replaced water to lower the CYA first, but not required.
    Re: Green Pool
    Quote Originally Posted by fannd View Post
    Total chlorine .8
    FC. 2.0
    PH. 7.9
    Alkalinity 100
    CYA. 70
    Total chlorine is 0.8
    38,235
    Re: Green Pool
    So how is FC = 2.0?
    TC = FC + CC
    Your FAS-DPD tests for the FC and then the CC ... those are what we care about.
    Casey's Avatar
    SW PA
    10,418
    Re: Green Pool
    Did you make a mistake and want FC to mean TC? it would make a lot more sense. That means you have 1 CC in the pool. Are you using 10 mil line to test? I'm not sure as I've never used the K2006 Kit.
    Re: Green Pool
    this was our first time using the kit and it was somewhat confusing. i will take another look at what we did and see if that is the case. thanks for your kind help.
  20. Back To Top    #20
    Jun 2013
    Fontana California
    56
    Re: Green Pool
    You can go to you tube and search Taylor 2006 chlorine test if you want to watch how to do the chlorine tests.
