Thread: Discharge hose
    Jun 2012
    NJ
    40
    Discharge hose
    We usually get a discharge hose from Leslie pool - works fine but is hard to stretch onto the filter output part. I was wondering if there was a better one out there that is easier to get on and stay on?
    http://www.lesliespool.com/leslies-d...harge-hose.htm
    NJ
    35,000 gallons, DE filter, IG plaster
    TF-100
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Discharge hose
    Just plumb it with PVC. Much easier and it doesn't need to be buried deeply.
    If you want to use the hose, I'd suggest dipping the end in very hot water for a while before trying to install it.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,974
    Re: Discharge hose
    Sounds like you're missing this.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Discharge hose
    Yep and if you have one of those you should have one of these to keep it on.
    Isolated Spa - 345 Gallons
    Jun 2011
    Central Iowa
    105
    Re: Discharge hose
    Thank you! I was missing the piece Richard320 posted and the blue plastic hose was too small to connect to filter. I've been using a smaller 4-5' hose and a kids slide to try and direct the discharge water away. it's quite the sight and honestly not working very well..... Adding these to my pool store list.....
    27' x 54" AG Morada RTR/19,300 gal/ 1hp-2spd Hayward Power-Flo Matrix/Hayward 256T sand filter
    Jun 2012
    NJ
    40
    Re: Discharge hose
    awesome thanks! definitely missing that $2 piece. We have the silver clamp - just have to try to stretch the discharge hose to get it on first but looks like that hose adapter will solve that!
    NJ
    TF-100
