Results 1 to 9 of 9
Thread: Those darn tests
    Jul 2012
    Forest, VA
    79
    Those darn tests
    So I have opened my pool for the year and regulated my numbers, but I have a few quick questions. First off, do I need to use the DPD-FAS test for every chlorine reading? I have the regular chlorine test, is that sufficient enough for general chlorine guidelines or should I be using DPD powder every single time? If I test every day I can see where that would be an expense. Also the CYA test seems a bit subjective. Depending on where I am sitting and what light I am looking in the CYA test comes out different. I do it at least twice and average. Does anyone think this? Thanks. Oh and is it better to test in the morning and add chemicals in the morning, or test at night and add at night?
    12,000 gal Octagon vinyl in-ground pool. Hayward S220 sand filter 3/4 hp pump, heat pump heater
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Those darn tests
    No you don't need to do the DPD-FAS test every time as long as your target FC levels are 5 or less. I don't even test everyday as I know my pools habits for FC. The OTO test will determine that you have chlorine present. It only reads up to 5 ppm. Your FC level is determined by your CYA level.
    The CYA test is light sensitive so it needs to be done outside in full sun with your back to the sun to create a shadow. Hold the vial at waist height.
    The best time to test and dose FC is in the evening when the sun is off the pool. That way your water has sufficient chlorine for the next day providing nothing is consuming it over night 😎
    Jeff
    Re: Those darn tests
    I use the DPD test every time, but I only test every other day "in-season" less than that off-season. I can't tell anything more than Yes I have some chlorine or No I have almost no chlorine from the other test.
    When to test really depends on what I am wearing.... if I have on good clothes, I may get a sample and test but wait and add chems when I am in PJ's or a swim suit. Still hoping for a bleach and acid proof lab coat some day -- with a TFP patch on the front, of course.
    I test both pH and FC every other day, then TA probably once a week, and CYA once a month or so. And when I start a new data recording sheet I test everything, for the record.
    Jul 2012
    Forest, VA
    79
    Jeff,
    Thanks for the info. My CYA is between 50-55 which makes my minimum 4-5 and my target 6-7. Being that my Taylor K-2005 has the drop dpd test that only goes to 5, I should probably use the dpd powder test for my FC tests for now until the splash out rids my pool of some CYA and the target drops below 5. Does this sound right? I also saw on the dpd drop test where you can dilute it to measure higher.....I take it this is not accurate?
    DPD tests up to about 10 without too many problems. You lose some precision, but for day to day use, with another option available when you need it, it is acceptable. Trying to measure above 10 DPD is useless.
    I use the OTO test day to day, just to check to see if something is way off from what I expect it to be. And then use FAS-DPD to check in more detail about once a week.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Those darn tests
    First how much sun is on your pool during the day ? You don't want your CYA too low. When you test for FC write down the results and how much you add to reach your target. You'll start to see a trend and you can skip some tests and just dose what your pool needs. Your pool will lose about the same amount everyday give or take 1 ppm.
    Jeff
    Jul 2012
    Forest, VA
    79
    Thanks guys for the replies. When the sun clears my house the pool gets sun all day. I would say from 9-10am until sundown. So I should be able to use the dpd for day to day and just use the powder approximately once a week?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Yes. I got the OTO confused with the DPD. Sorry about that.
    With that much sun on your pool I wouldn't let the CYA level drop below 40.
    Jeff
    Jul 2012
    Forest, VA
    79
    Great thanks! You've been a great help.
