Thread: Intex 635T Pump Leak
    May 2013
    Lacombe, LA
    19
    Hey Gang,
    New to the forum, I appreciate you taking the time to read my post. I'm at a dead end at the moment. I have a leak from my filter pump, that much I know is clear.
    Let me give my 'what I've tried'
    I noticed when I had done my spring maintenance to get my pool back up and running, there was a dreaded puddle of water in one corner of my pool. I didn't think much of it, but turns out I was looking water in my pool! I went through my pool liner with dye solution, and I had nothing come out of the liner (a good thing!). To make a long story short, I've traced the slow leak to the filter pump. I use a salt water system with it, and I've thoroughly checked that. When the pump is in action, I see the leak coming from the actual pump unit. I've disconnected my hoses and replaced both.
    Anyone have suggestions? I would greatly appreciate it!!!!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Intex 635T Pump Leak
    Welcome to tfp, mrpuckman
    Can you post a picture of where the leak is on the pump?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Welcome to TFP!
    Is it the pump housing or is it leaking from where the housing attaches to the pump body?
    Could you do us a favor? Please add your location and pool info as suggested here.
    This will help us to help you.
    May 2013
    Lacombe, LA
    19
    I appreciate the help! It looks like I might have pulled a 'dummy'. It occurred to me that I didn't do the obvious thing.
    CHANGE THE FILTER
    So far, so good....
    I feel dumb!
    5,500 Gallons
    AG - Intex 16x48 Ultra Frame
    Intex 1200 GPH Krystal Clear Sand Filter Pump 28643EG
    Saltwater System
    Install - 05/2013
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    May I suggest a Unicel cart?
    http://www.unicelfilters.com/pdf/replacement_guide.pdf
    Look in the 4000 series for your filter. I can guarantee the Unicel filter will do a better job for our pool.
    In fact, here is a twin pack for a decent price, on Amazon, sold by and shipped from VMInnovations.
    May 2013
    Lacombe, LA
    19
    Thanks Charlie! I apologize it has taken so long to get back to you, love the suggestion! I'm going through those other filters fast. This would definitely seem to be a better route.
    5,500 Gallons
    Saltwater System
    Install - 05/2013
