Results 1 to 7 of 7
Thread: Please weigh in on these 2 sand filter/ pumps...
    Jul 2012
    NW FL
    91
    Got the pool and swg figured out, now for the pump/filter
    I am looking at buying one of the two for an 18' x 52" easy set (ring)pool...
    thoughts?? for the size difference, do you think there will be much difference in overall results???!
    http://www.amazon.com/gp/product/B00...=AGOKDG42D8KUC
    http://www.amazon.com/gp/product/B00...A1DXN92KCKEQV4
    thanks...
    ~6500 gal 18' x 52" easy set agp, 7th year
    Intex 2650 sand filter, chlorine
    TF100 Test Kit
    Becoming a TFP lifetime supporter and purchasing the TF100 is absolutely the best money I have ever spent! :-D
    Re: Please weigh in on these 2 sand filter/ pumps...
    If you can afford it, I would go with the larger one. Many people have posted liking the larger one, while the smaller one is both less common and not so uniformly liked.
    Orlando, FL
    690
    Go with the 2650 but if you can wait, I bet that price will come down. I paid $140 last year.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Orlando, FL
    690
    Check Walmart. Com
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    2650 sand filter...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Jul 2012
    NW FL
    91
    thanks everyone... I need a cofidence boost every now and then.
    TF100 Test Kit
    Apr 2014
    Gardners, PA
    69
    I have the 2650 I bought back in 2012. Back then it cost $200 and it has the blue color plastics like the smaller one. But it works well for a 24' round pool and I like the built in timer. I can match it with the timer on my SWG. So far very happy with it.
