Thread: Messed up situation
    Messed up situation
    I have a 11k gallon plaster pool, It was drained and acid washed 2 years back, I went for water testing and the CH level is really high 1000... The pool store recommended to drain the pool again. BUT The problem is the weather is already hot in Phoenix 80-90 degree, What shall I do ?
    11000 Gallons, Cartridge Filter, UG, Plaster, Shasta pool, filter model Hayward C4030, Pump Motor Emerson 1-1/2HP Full Rated EB2977T, Pump model Northstar SP4010NS
    Re: Messed up situation
    You don't need to lower the water level to replace water. It is possible to drain at about the same rate you are filling. This process is a little less efficient in terms of water usage, but it prevents any risk from heat damage to the plaster.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Reverse Osmosis is available in the Phoenix area. Calsaway.
    38,284
    Have you been using as lot of the chlorine powder from they pool store? No way the CH should be that high already if you were not adding calcium.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Good suggestion. If I could swing this, I would do RO treatment.
    Then look into this. I live in a high CH area, and they sell Cal Hypo all day every day. It could well be the culprit.
    Essential Links:
    30,419
    fbs,
    Do you know the CH of your fill water?
