Results 1 to 8 of 8
Thread: Sand Filter Base
    Apr 2014
    NM
    11
    Sand Filter Base
    I have a Sta-Rite Cristal-flo 24-inch 300lb filter. It is about 16 years old. The plastic/rubber supporting base split in halve and the filter has been dropping a little. I now have the sand out for replacing. An exact replacement stand is no-longer made and the ones that may be available are over $100. Are there generic stands that are available and can be used? Any advice on making a new one or perhaps using my two split halves? Thanks!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Sand Filter Base
    I would be concerned that if the base had decayed to the point of splitting that the filter itself may not be far behind, this is a particular concern since these types of filters are also pressure vessels, but I am extra cautious regarding things that can go boom, even when the chance is slight.
    golfinglenn's Avatar
    Jul 2013
    Springfield, OR
    96
    I know on my sand filter the base is a totally different compound than the filter itself. If it were me I would make a replacement base out of plywood and 2x4's. You could use the current base as a template, or a contractor could bust that out in about 20 minutes.
    6500 gal above ground Doughboy with 200lb sand filter and solar panel heater. Converted from Baqua to BBB and never looking back!!
    Apr 2014
    NM
    11
    Yes, the base is a totally different material.
    Apr 2014
    NM
    11
    When thinking 2x4s and plywood, is the idea to make a circular hole in the plywood for the filter to fit in and then prop that up to the desired height with 2x4s and other sized wood ?
    Apr 2014
    NM
    11
    Any other good ideas? Thanks!
    Oct 2012
    Central Ohio
    180
    Do you have the dimensions of your current base? and a pic. I may have 1.
    Quote Originally Posted by Greenpool88 View Post
    4x4 frame and a car tire J/K
    Rob
    Cozumel AGP 24' 14,700 gallons
    Pentair Dynamo 1.5 hp pump
    Sta-rite Cristol-Flo II 2.3sq.ft. sand filter
    SWCG,Uni-bead liner
    Borates
    TF-100 Testkit....$68,cheap insurance for a trouble free pool season
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Mine is sitting on an air conditioner compressor equipment pad-------gray plastic.
