Results 1 to 10 of 10
Thread: Ammonia and high chlorine demand.
    Jun 2013
    Augusta, GA
    90
    Well, seems that I am dealing with one of those instances where my CYA was converted into ammonia.
    I am helping my folks open their pool in south jersey, and got a reading of 0 cya with my tf-100. Strange because they used nothing but tablets last year. Sooo, after 16 gallons of 10%, and 4 lbs of cya, I still cannot get my Fc to hold above 5, while my cc is between 7-11. Btw, 18000 gallon inground, covered all winter.
    30'x52'' AGP 21,000 Gallons
    TWM 2.64 SF Sand Filter w/ Century 1.5 HP Pump
    BBB'er for life!
    TF-100 Test Kit
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    The CYA addition may have turned some of it back into ammonia. Just keep adding chlorine, SLAM level. You'll burn through chlorine rather fast. It'll eat the ammonia up in time. Keep at it until you have CC of 0.5 and you can hold FC.
    Jeff
    Jun 2013
    Augusta, GA
    90
    Re: Ammonia and high chlorine demand.
    As of 0730, FC 4 CC 15. And I am out of liquid shock.
    BBB'er for life!
    TF-100 Test Kit
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    You can use regular bleach also. Your gonna have to go get some. Might take a fair amount.
    Jeff
    Jun 2013
    Augusta, GA
    90
    Right now I am getting the 10% for about 3 bucks a gallon, and with the amount I am going through, i welcome the concentrate strength.
    BBB'er for life!
    TF-100 Test Kit
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Sounds good. I know it's a pain but ......
    Jeff
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    I've never seen a reading of 15CC and don't even know if it's possible. You sure about that?
    woodyp, CC around 15 is quite common when cleaning up CYA that turned into ammonia. The reaction that turns chlorine plus ammonia into CC runs very quickly, while the reaction that further breaks down CC runs much more slowly. Since the chlorine is getting used up very quickly in the first reaction, there isn't any left to drive the second reaction. The balance will shift later in the process, and CC will start to come down, but right at first very high CC levels are common.
    Apr 2010
    East Texas
    9,609
    Thanks Jason. I just knew that around 3 or 4 CC is all I' have ever seen posted in testing results.
    Mar 2007
    San Rafael, CA USA
    12,082
    Also keep in mind that one can do a bucket test with pool water to see the total chlorine demand. If it's extraordinarily high, then a partial drain/refill is another option to reduce the amount of chlorine needed if water isn't too expensive in your area.
