Results 1 to 12 of 12
Thread: Last years tf-100 leftovers
    May 2013
    Missouri
    53
    I bought new testing supplies for this year but I am wondering if the DPD powder from last summer is still good. Hoping to not need to SLAM my pool this summer but just in case I need to, I thought it would be nice to have the extra powder around to use if I ran out of the new stuff. What about the rest of the supplies, is any of it worth keeping? Today was my first after winter opening and I have a quick question- if my cc was 0 and my water clear, do I need to still do an overnight test or is it safe to assume my pool is algae free? Thanks!
    June 2013 24 x 52 Sharkline Heritage AGP (13,500 gal), 2 speed 1 hp pump, 150 lb filter(?), TF-100 test kit
    My first pool ever, pool school student with lots of questions
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Last years tf-100 leftovers
    If you've kept them indoors there should be no worries. I would use them, and if you are worried with a strange number, re-run it against the new reagents and see what you get.
    I am betting they will be good if they have been properly stored as I mentioned.
    Essential Links:
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    My reagents are over a year old and they still work. I have new ones just haven't used them yet. If you store them correctly you'll be fine.
    If your water is crystal clear and no CC and no visible algae your good to go.
    Jeff
    Casey's Avatar
    SW PA
    10,457
    I am using reagents from last year and I trust them. I keep mine under the sink on the shelf. I pull it out, test the water and put it back.
    I didn't SLAM my pool upon opening because my CC's were 0 with an FC of 4ppm.
    38,521
    Some of the reagents I am using are over 3 years old
    I have newer ones, but I continue to get expected results. Stored properly they can last awhile.
    The powder and the CYA reagent I think are the last ones to worry about. Crush the powder back up if it clumps.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    I am using up last years refills as well. The DPD powder has turned a shade of grey, but still works fine.
    May 2013
    Missouri
    53
    Thanks!
    30,432
    Each of you above are badly denting my refill sales.
    The biggest problem is that you are all telling the truth.....with PROPER storage, the chemistry lasts a pretty good while.
    38,521
    Sorry about that Dave
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Don't worry, Dave, I'll be needing a refill or three soon.
    I've got enough FAS & DPD for another couple of weeks, and will need more R-0013 soon too. You know where I'll be getting them.......
    I left mine in the garage and they froze. The only thing that is usable is the powder. wont make that mistake again.
    24' round AGP 17Kgal. TF 100, BBB method all the way
    38,521
    Dave thanks you
