Results 1 to 7 of 7
Thread: Big fan from L. I.
    Jun 2008
    Deer Park, LI, NY
    10
    Big fan from L. I.
    Hey, I'm Jeff.
    I'm a power plant engineer in NYC and just bought a house 2 yrs ago with a 16*32 IG 20,500Gal
    It has a lop loc cover and its been a swamp the past 2 years I've opend it.
    last year i had a pool company open it many to se what they did which was pretty much, pull the over off letting every thing on the cover drop in. It was a swamp they set up the pump, said keep shocking it, and run the filter.
    Great, well every time I vacuumed, the DE filter and the suction basket and the skimmers would get plugged. So with the help of Ebay, bought a 1.5hp hayward superpump, hayward cx900 cart filter and a few valves and PVC and build a stand alone vac pump. worked great. Wasn't into the chems like i should have been, Just watched the Cl and PH with a little drop test kit i bought. Seemed to work. Water stayed clear most of the season, Weather was cool and only was in the pool 3 times, hate cold water!!
    This year It was "Do it yourself time." with my tag line "How hard could this be."
    I pull cover, I see black swamp. I shock , I shock. I pour hypo 5.3%, baking soda, I find this website and its like chem class all over again. 7.0/7.3, 8.0 oh shoot how the **** that happen, TA=50/80/180? shoot.
    I decided to replace the DE filter, only because I have nowhere to backwash it.
    I replaced it with another hayward cx900 using the same 1.0hp superfilter.
    while i was trying to build new piping I had a jumper hose from the skimmer suction to the vac pump.
    I figured this will clear up shortly, One mans shortly is another mans long 2 weeks. after i started i got called for jury duty and had to stop everything in the middle, long story short, after 3 weeks and over 40 gals of hypo and powder shock and other stuff I should have not even bothered with I'm starting to see the bottem of the deep end.
    When they say POPP oh man do they mean it!!!
    Good luck to everyone who knows whay a swamp means!!!
    jeff
    HOW HARD COULD THIS BE? Any Day Now I'll see the Bottom
    07/05/08= My wife say's "I see the bottom!!!"
    Just the facts=20,500gal IG with
    1) cx900 hayward filter, 1.5 hp pump for vac
    1) cx900 filter and 1.0 hp pump for skimmers
    Using Skimmer Socks in pump baskets and skimmers,Electronic PH Meter
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Big fan from L. I.
    Welcome. So, just so I understand, is your water clear or is it still a swamp?
    Your in the right place, glad you found us....
    Jun 2008
    Deer Park, LI, NY
    10
    I have a white liner with blue dots on it and I can see the dots on the deep end and the vac head on the rod. Its still slightly cloudly but can see the side walls and most of the rest of the pool. I posted my numbers and a short saga on algae fourm. I got a reply to shock more, i cant lift any more gallons of CL, haha
    Next yr I'm just going to order a pallet from the pool store and start from there, or buy a couple of 55 gal drums and get a bulk order.
    jeff
    Butterfly's Avatar
    South Carolina
    10,045
    Hi Jeff,
    Welcome to TFP!
    We're glad to have you.
    You're done SLAMing when:
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Quote Originally Posted by PHOTOFPD
    Nahhh . . . because next year you're not going to open a swamp. You will have learned how to keep your pool clean with really very little time, effort, and money. While the Swamp Thing is always lurking, ready to move in, we know how to hold it at bay!
    Welcome to TFP! I liked reading your success story, especially the part about POP.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    Jun 2008
    Deer Park, LI, NY
    10
    The end of this yr. I'm thinking about putting a solid cover over my lop-loc cover, has anyone done this? good idea?
    I have trees on every corner of the pool and the leaves and dirt in the spring and fall is unreal.
    It just sits on the cover and rots, this is the second yr I fought the swamp.
    Its clean and clear now. But I really dont want to do this next yr.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    If you put a solid cover on it, you'll have to pump the water off regularly. My Loop-Loc is flat, and leaves etc. just blow away after it dries a day or two. Maybe your water level is getting too high and holding the cover down. I drain mine to the skimmer 2 or 3 times during the winter.
