Results 1 to 7 of 7
Thread: The numbers game
    Jul 2012
    Forest, VA
    79
    The numbers game
    My pool has been open for a few weeks and looks really good. Numbers are solid. The temperature is still really cold and we will not be swimming for a while. Should I just keep the FC and pH at the target levels? CYA is around 50-55. I have been keeping the FC around 5-10. According to the CYA chart my FC should not be below 4. Am I doing this right? thanks in advance for your replies.
    12,000 gal Octagon vinyl in-ground pool. Hayward S220 sand filter 3/4 hp pump, heat pump heater
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    The numbers game
    I think your doing fine. Just maintain your levels like your are. Make sure you don't let your FC fall below the min. Do you think your CYA is closer to 50 or 60 ?
    Your using liquid chlorine I hope ?
    Jeff
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: The numbers game
    Sounds like you are doing well with FC and have an understanding. Your range is a little broad, but if you understand the target for Cya and you aren't letting it slack, then you are on the right track with that.
    Essential Links:
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Jul 2012
    Forest, VA
    79
    Fresh #'s:
    FC 4
    CC 0.5
    CYA 50
    Alk 100
    pH 7.8
    Yes I am using liquid bleach, and b/c the FC is four, I will add about 41oz. to bring back up to 7. Also add a little Muriatic acid.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    The numbers game
    Yep raise your FC up. Your right at the min as you know. When you get into higher chlorine demand you can go to 8. That'll give you more wiggle room for burn off so you don't fall below the minimum.
    Thanks for the test results. Your doing a good job !
    Jeff
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    +1 to Jeff's comment.
    Bring that Chlorine up so you have some residual to spare at all times.
    Essential Links:
