Thread: Is 60 for Calcium Hardness OK for vinyl pool?
    Mar 2007
    Ontario
    211
    Hello:
    I thought I read here that calcium hardness is not that important
    for vinyl pools. I would just like to confirm that 60ppm is fine for
    an inground vinyl pool. Thanks
    16x32 inground vinyl 8' deep end
    1hp Northstar Pump, 20" Sand Filter
    6ft Double Lounge, 2 Aqua Lamps w/remote
    216sqft Sungrabber Panels (9- 2'x12') a little undersized
    Jul 2007
    Waterford Michigan
    36
    Re: Is 60 for Calcium Hardness OK for vinyl pool?
    It's not realy a problem at that level but if your Ph starts to drift you could end up with some foaming issiues. You would be better around 150.
    15x30 AG
    Cartridge Filter
    Solar Heater
    1.0 HP 2 Speed pump
    + 2 KIDS
    Guest
    Quote Originally Posted by dbrown199
    pH really has no impact on foaming, only the hardness. 60 ppm is fairly soft water and it will have a higher tendency to foam than harder water (with higher CH). IF the foaming is not a problem you are fine but if you see any foaming then increasing the hardness to a minimum of around 150 ppm can help.
    Mar 2007
    Ontario
    211
    Thanks for the replies. I love this site?
