Results 1 to 10 of 10
Thread: Ice Damage to our pool
    The winter was tough for us this year with more ice than normal. It ended up pulling our skimmer down through the side of the pool and tearing the liner. My husband plans to use sheet metal to repair the side of the pool but we're wondering if we could repair the hole in the liner or if it's just too big and/or in a bad location and we need to replace it. I'm attaching a photo of it. The large hole in the side is the spot where the skimmer belongs. The liner is 6 years old. Our water is turning quite green and we want to get at it before we have a major cleanup if we can keep this liner. Thank you for your help.
    Gia1975
    27' above ground
    17,100 gallons
    sand filter
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Ice Damage to our pool
    You can see if you can get a piece of a liner and try patching, but I doubt it will hold for a full season. If you do try, make sure the patch extends 4-6" past the torn area. More glue surface may make the difference.
    The problem is there isn't 4-6" to glue to all the way around, the top gets much closer to the track than that. The odds of a successful patch are very low.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    If it's in the budget I'd get a new liner and be done with it. That's a pretty bad tear. I'm not sure how well a patch would hold up.
    Jeff
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Kinda what I was getting at, but I don't like being the bearer of bad news......
    Casey's Avatar
    SW PA
    10,461
    I would definitely retire that liner. It was a brutal winter.
    Thank you everyone. I was afraid of your response, but expected it. The cost of the liner isn't the problem but the cost of the water is. We'll probably try to patch and hope that it holds for a while at least until we can handle the rest of the cost. Is there a thread on the best type of liner? We had been given our pool by a neighbour when they wanted to put up a garage in its place. They had actually used the liner for one season before passing it on to us. We were pleased that we were able to use it still. So we've never bought one.
    Gia1975
    27' above ground
    17,100 gallons
    sand filter
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    The best liner is the thickest. 25 mill at least. IMO the liner is not something you want to skimp on.
    Jeff
    Casey's Avatar
    SW PA
    10,461
    You can try yo save it but if it let's loose, you may lose more than just the liner... you risk major pool damage, the water loss you're so concerned about and possibly a life if you or anyone is in the pool IF and WHEN it lets go. The risks are there and up for the taking if you so choose.
    Mar 2014
    Thomson GA
    166
    above ground pool liners
    You will find many liners for sale, many with free shipping.
    Good luck with your pool and be safe.
    Gerry
    27' x 54" AG Salt Water Pool Installed 2014, Hayward 23" Sand Filter, 1 HP 2-Speed Power-Flo Matrix Pump, AQ-TROL SWG, TF-100 Test Kit
